Simplistic NJFET RIAA - Page 305 - diyAudio
Old 29th January 2010, 08:53 PM   #3041
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Trim trim trim.
Old 29th January 2010, 09:35 PM   #3042
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Very rewarding work this is
Old 29th January 2010, 11:35 PM   #3043
merlin el mago's Avatar
Originally Posted by RCruz View Post
Confused with the different sonic results from bypassing riaa caps in my three riaa, I decided to buy a decent LCR.
I got a TENMA 72-8150 that states an average precision of 0.5% in capacitance reading.
After that I desoldered the 47n caps in the 48dB unit and measured 47.6 R 47.1L.
No wonder the sound lost magic when I added 680p //
In this design we should not overshoot 47n
Congratulations for the new LCR, could you post a picture? How much cost it?Now I will ask you to measure mine caps
Thks for advice not overshoot RIAA caps.
Old 30th January 2010, 11:18 AM   #3044
nhinstruments
RCruz's Avatar
Here you have.... quite inexpensive but correct reading
TENMA|72-8150|MULTIMETER, CR | Farnell Portugal
Old 30th January 2010, 11:19 AM   #3045
nhinstruments
RCruz's Avatar
Now the 48dB is sounding right !
Must do the same procedure in the 57dB machine..... It is a pity I must disassemble everything again.
Old 30th January 2010, 10:27 PM   #3046
nhinstruments
RCruz's Avatar
Today I dismantled the 57dB machine, desoldered one leg of the 47n cap, measured 46.5 and replaced the // 680p by a //560p.
This happened in both chanels..... The difference is amazing.... Now it really sings (and it uses only one shunt) ... maybe a second shunt is redundant but I will try it anyway
Old 31st January 2010, 03:50 PM   #3047
nhinstruments
RCruz's Avatar
Now I completely removed hum !!!
It is incredible.... using an inboard r core and beeing carefull about GND I got even lower noise with the 57dB than on the 48dB I built before with external double psu´s.
After studying the schematic for a while, I decided to lift the psu GND and now there is no hum.
Maybe I will need to rethink this when I add the second shunt but for now I have a "floating GND" psu.
Old 1st February 2010, 12:55 AM   #3048
Salas's Avatar
Well done Ricardo. Maybe its suitable to the 4 pole cap as it seems.
Old 1st February 2010, 09:32 AM   #3049
nhinstruments
RCruz's Avatar
I am really happy because with an r core we can have even better results than with toroids in an external box.
Old 1st February 2010, 01:12 PM   #3050
Ricardo, in mine tests the external EI-cores give better results than external R-cores or Toroids, if you can not do it external the best are R-Cores. Could you try external EI-cores?
Copyright ©1999-2017 diyAudio
