Simplistic NJFET RIAA
I agree.... the real issue might not be the uTeslas generated by the DVM but the current passing in the coils.
Several years ago I managed to burn the coils of a cheap MC while trying to determine the correct polarity using a voltmeter working with one 1,5v bat.
After a few days listening to the RIAA, I can say that I am really happy with the final result. A big improvment from my previous non cascoded build. More dynamic, more resolution, more 3D sound, more of everything. Also it is very balanced. It' s like having another stereo! It was well worth the effort put in building it.
Also FYI, I changed to battery bias bias and put an 470nF FT-3 output cap (I liked this very much! I would like to have a similar value of Mundorf silver gold oil to compare. It is going to be difficult to better it.) on my #26 pre and things improved even more.
Everybody serious about records should give this a try. It' s one of the best sounds I ever heard.
Nice one VG, enjoy. What is that blue wire in the phono? Some grounding to chassis? Also what type is the output twisted pair? That No26 DHT line pre is a big machine now I see it with its separate supply box, by the way. Should have taken quite a construction effort.
the blue wires were temporary are they are removed now, as I run a seperate ground wire from the PS box. The picture is from yesterday.
As I have two big 10H chokes, heater pregulation with 2x15000uF per channel, 3 transformers, 2 anode chokes and 2 SSHV, I do not think I can do one box!
This was morphed from my previous 12b4 pre, so there are a few extra holes!
Congrats vgeorge, very nice system, for sure sounds very very good🙂.
To aid ventilation, you planned it all along.🙂 What kind is that cotton jacket(?) twisted pair wire you use for linking the phono output to the boards?
First change the load and then play with the HF Riaa cap. Also 180R load is possible.
Tryed with 220R Caddock MK132, 1st impressions is that the sound has more punch or dynamics so more mids & lows also more noise than the Vishay Tx2575 but can't come back to 150R, when I have the money I will order 220R Vishay Tx2575 to Michael Percy. Thank you for great input Nick, now is time to tweak the Riaa HF cap so I will change 15nF76 SM to 15nF teflon film & foil, I will tell you what happens....
OK. Keep 150pF extra caps to make tuning steps. VG's 15mA Vjfet custom simplistic lends it self for 15n straight Teflon by its intrinsic alignment I used, yours may need a bit more than 15n or not. You will see.
If there is no buzz (zzzz 100Hz to 1kHz harmonic noise) from the source, just different hiss from the line preamplifiers does not have to do with the twisted pair, and you may keep it since your system tonality is great as it is now you say, not to disturb it.
I have a couple of shielded interconnects which seems to me less dynamic than the ones, pure silver, that I am using now. With the tubes, there is slight buzz only listening right at the speaker. I am certain with different tubes and a little work on layout can make things better. Tape noise from analogue recordings is a lot louder.
For the moment I am listening one of the best sounds ever listened.
I don't have shielded output wire either. iMHO it is better to avoid it if you can to minimize capacitance. I usually don't run shielded interconnect either. only when I have to.
If you use twisted pair you are adding capacitance also....if you use parallel wires it's capacitance symbol so exist also capacitance, less what still have...so doesn't exist a couple or more wires without capacitance, you can minimisize the effect if you use a Litz geometry or separate with the maximum lenght possible the wires (this last one difficult to do for chassis wire)
