Simplistic NJFET RIAA
Old 14th December 2009, 12:38 PM   #2751
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Joao@AltheaMusica View Post
Agree with your sight of view. When this is your "entry level" how is your highest level in phono amplifiers? Just interested if you will give me / us some short possible forecast on your designs?!
But I am not a designer. I just DIY something if a need occurs for my system or for a mate. Usually simple and cheap enough. J. Gerhard's MPP may be interesting for you.
Old 15th December 2009, 09:36 AM   #2752
Joao@AltheaMusica is offline Joao@AltheaMusica  Switzerland
Followed this thread but this stuff is not "my cup of tea" ... if I want to build such similar one there exists many good devices to work with.
No I'll try out the single ended phono stage, this is nearer by my valve topology. BTW, do you know an substitute for the 2SK389/2SJ109, a dual JFet?
Old 15th December 2009, 09:43 AM   #2753
Salas's Avatar
Burning Amp Festival 2009
There they talked about something Linear Integrated Systems is to produce.
Maybe you can investigate further.
Old 15th December 2009, 11:00 PM   #2754
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
[QUOTE=Salas;2011900]The hiss is due to the wire, not the core. Detail smothering level or tonal coloring can be due to the core and general construction. Trafos are specialist stuff, you guys know which one suits better what cart etc.
QUOTE]
So even choosing a R core, one must be carefull about the wire used in it right ?
Old 16th December 2009, 06:11 AM   #2755
Salas's Avatar
Its not about quality. Its the physics of noise. Has to do with turns and impedances needed. Talking head amps.
Old 16th December 2009, 02:45 PM   #2756
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Just low.
Hi Salas,
Instead the Benz Micro Ace Red Low that cost: 60000, what about this cartridge Audio-Technica AT33PTG is more economical & the specs seems really impressive & cost 389$00 = 28000 aprox. only available in Japan:
Specifications
Type: MC type
Playback frequency range: 15 - 50,000Hz
Output voltage: 0.5mV (1kHz and 5cm/sec.
Channel separation: 30dB (1kHz)
Output balance: 0.5dB (1kHz)
Stylus pressure: 1.6 - 2.0g (1.8g standard)
Coil impedance: 17 Ohms (1kHz)
Direct current resistance: 17 Ohms
Load resistance: 20 Ohms or more
Coil inductance: 70 mu H (1kHz)
Static compliance: 40ױ0 - 6 cm/dyne
Dynamic compliance : 10ױ0 - 6 cm/dyne (100Hz)
Needle tip form: Micro linear (ML)
Vertical tracking angle: 23?
External size: L26.5 W 16.6 H16mm
Mass (cartridge): 6.8g
Thks in advance for your kind advice
Merlin El Mago
Old 16th December 2009, 02:53 PM   #2757
Salas's Avatar
It will give very good SNR too. But I have never listened to one. I hope it does not remind other AT MC that had always stricken me as ''thin'' in midbass.
Old 16th December 2009, 06:20 PM   #2758
nhinstruments
RCruz's Avatar
IMO the Benz ACE is a very good compromise for the price.... Lower cost Benz like the MC Gold ($350) sounds very coarse, undetailed... and imagery is worst than a DL160.
Low cost Ortofon (Like MC10) sound very thin.... the good ones (K) cost more than $600
If I was to choose a lower cost cart I would try to listen to a Sumiko Blue Point Evo3...
Old 16th December 2009, 06:23 PM   #2759
I listened one AT OC09ML & mine impression is that no have thin bass, possible not deep as I like. I like the solid & deep bass, not inflated & without control. What about the sonics of a Denon DL-103 it's similar like The Denon DL-304?
thks again
Merlin El Mago
Old 16th December 2009, 06:54 PM   #2760
Thanks for your opinion Rcruz, Sumiko Blue Point Evo III is an MC with high output: 2,5mV, the specs are good & seems matched perfect with mine Linn Ekos, another good option in MM will be Clearaudio Virtuoso Wood 54500 or better the Clearaudio Maestro Wood 68000, but initially I prefer MC low output between 0,3 or 0,4mV?
Simplistic NJFET RIAAHide this!Advertise here!
