Simplistic NJFET RIAA
Old 20th November 2008, 10:50 AM   #261
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Thank you Salas
You made it perfectly clear to me now.
Maybe I will use a 220uF BG on the output.... I really like BG sound.
Ricardo
RC
Old 20th November 2008, 12:49 PM   #262
massimo is offline massimo  Italy
Kalimera, Kirie Salas!
Just one question about your shuntreg: why did you use such a beefy TO247 mosfet for the CCS and the parallel device? It's only 120 mA for the first one and much less for the second. Wasn't a TO220 mosfet (such as IRF9610) enough for this purpose?
(OK, OK, I know one possible answer: I picked up what was available in my drawer.....)
P.S. I like the idea of a P device for the shunt, while many others use N devices that amplify the noise.
Old 20th November 2008, 03:50 PM   #263
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Beefy usually sounds...errr...beefy. Plus it will not create instability so easily as a very fast one, plus low Rds On (9610=3 Ohm, 9240=0.5 Ohm). In my initial concept explanation I talked about faster TO220 Mosfets too and that many devices will do. Open to experiments. Also we may run Amperes even if we feel like spending money and space on transformer and heatsinks. It will sound different maybe. Also 9240 has good availability.
As it is now, the sound opens very noticeably in dimensional scale, cleans up a lot, the focus of each instrument becomes very certain, and the overall musical detail gain is breathtaking.
The concept is easy, please experiment with Mosfet types and capacitor values and qualities as much as you can.
Old 21st November 2008, 04:21 AM   #264
Salas's Avatar
One last thing. For those who are going to use RIAA versions requiring under 30V B+ better use 4.7k resistors for the current source BC560 instead of the 6.8k ones in the 37V B+ example. That way its current stays about the same level as in the example. Taken that the Vin is +6 to 8V up Vreg.
And a hint. Auricaps sound nicely warm and beefy at the final output coupling capacitor position in my RIAA. But that is a system match and preference area. You know all that.
Old 21st November 2008, 05:37 AM   #265
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I had a look at the shunt regulator posted here, and I couldn't resist twiddling with it. Attached is my simulated take, with a fast pulsed load attached for testing.
Old 21st November 2008, 05:41 AM   #266
wrenchone's Avatar
Here are the simulation results. The regultor is fast, low impedance, and should be pretty low noise. Whys and wherefores will follow when I feel like writing them. In the meantime, dissect it into component functional blocks and think about it for a bit.
Old 21st November 2008, 02:50 PM   #267
Salas's Avatar
Nice! Can you substitute BC560, BC550 & 2SK170, so we can do it in Europe easier too?
Old 21st November 2008, 03:02 PM   #268
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Some friends are substituting adjustable shunt regulators for zeners in their microphones. Any thoughts? It's nice having one part for all voltages, no TC, much less noise, very low min current.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 21st November 2008, 06:19 PM   #269
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Today I finally found time to build this circuit. Unfortunately, I am not getting any sound output.
Being pretty noobish, I have a noobish question if you don't mind. I'd just like to check that I have the FET's and transistor the correct way round. Which pins on Q6 are tied together please? And is it pin 1 of Q3 (bc550) that connects to Q1?
Cheers, Lee.
(Confused as to why it won't work)
Old 21st November 2008, 07:58 PM   #270
mikvous is offline mikvous  Greece
Lee,
Which version are you trying.Don't worry we'll find it
Simplistic NJFET RIAAHide this!Advertise here!
