| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#2621 |
diyAudio Chief Moderator
FT2=FT3 both equal in this application. I have tried both, I prefer the latter due to size only. +280pF-330pF you must use.
#2622 |
Salas
searching around the web I see people use 140 to 180r to 500r to 840r burn in min 15h |
#2623 |
I need to place a power on indicator in the psu, using a led.
I am using raw DC just after the rectifier bridge (ex: 40v) and need to know: What is the minimum current the led needs to operate ? Does this led current affect noise produced by the led ? I am reading most leds need 20mA... can I use 5mA ? |
#2624 |
#2625 | |
#2626 |
for who have the basic 103 plus a strong heart
DL-103 Last edited by nicoch58; 5th November 2009 at 04:10 PM. |
#2627 |
I am not into mechanical tweaks, I would mess it up. But I will try for the electronics to be good.
#2628 |
your R don't need the mess
![]() as already have damper on the body Last edited by nicoch58; 5th November 2009 at 05:18 PM. |
#2629 |
I have a basic 103 and I have put a wooden body on it.
I can tell you that it was not so hard to do it. I haven' t listen extesivly to it, but it looks much better! |
#2630 |
New dl160 riaa psu recipe:
One 2r2 mills resistor before the Jensen 4 pole 15000u. Voltage droped only a little (as expected) and now I get 39,5v on shunt Vin. I get lower noise and better detail + spaciality. |
| Page generated in 0.13250 seconds (58.36% PHP - 41.64% MySQL) with 11 queries |
