| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#2611 | |
diyAudio Chief Moderator
Those huge micas are better than modern little micas. But if you can find modern pp film & foil its a good alternative. Has to work synergistically with the interstage. You cook. If small and good the layout gets tighter and that is a plus. Polysterene old is good, modern I am not sure. What about RCL polysterene? |
#2612 |
for what I read..... modern RT (not rtx)polystirene is the best "cheap" alternative to modern teflon .
silver/mica is more brigth vs poly , but only read......need the Cruz certificate tester |
#2613 |
The big Soviet MIL SPEC NOS lacks the brightness. That's good, but its huge for layout. What I do sometimes, is pp//MilSM small value.
#2615 |
Guys, before making comparisons on capacitors based on taste and under varying conditions, I'd like to point to this very well written text. It has a scientific nature but it reads easily. Pay attention to the explication of self-resonance on page 6.
Regards, Jaap.
jaap |
#2616 |
#2617 |
wow good shot salas
I use 180 for my 5ohm , standard is 100 for 5r |
#2618 |
So 1:20 minimum you suggest. Then I will have to use min 14:5=2.8*100=280R. Ok will do when ready. 1:36 you use for your 5 Ohm leads me to 504R. A good bracket.
#2619 |
some put copper (alu) plate , or copper ring
between arm and cartridge ,and nylon washer |
#2620 |
Salas, ready to build my 2nd Simplistic RIAA with recommended parts
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| jybe |
| Page generated in 0.16384 seconds (68.46% PHP - 31.54% MySQL) with 11 queries |
