Simplistic NJFET RIAA
Old 1st September 2009, 09:27 PM   #2201
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Marinos View Post
Matching again..
I have a pair of 15.73 nf for RIAA. Is it worth to parallel 270pF to get exactly 16 nF or I'm overdoing it ?
It is worthwhile, and much audible in this case. It controls the overall voicing tilt. You can overshoot to 16n1, but don't let it be under 16n.
Old 1st September 2009, 11:45 PM   #2202
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by disco View Post
I have to confirm this phono is revealing
Has anybody perhaps tried this isolator?
You can be sure it is revealing !
Regarding the isolator.... Do you believe the top screws are not connected to the lower nuts ?
I mean, does the isolator alow any compliance beween the arm and cart ?
Looks like the rubber part that isolates the counterweight from the arm tube in a SME3009....
Ricardo
Old 1st September 2009, 11:50 PM   #2203
nicoch58 is offline nicoch58  Europe
for the isolator I have read good and bed ...as Salas suggestion better fun DIY ,copper ,nylon washer/screw ,not so tight ...
Old 2nd September 2009, 03:10 AM   #2204
psgr is offline psgr  United States
Rcruz- do you have dimensions for your pcb layout posted in post #2180 ?
I will include it in my next revision. Is this OK with you ?
Pete
Old 2nd September 2009, 03:26 PM   #2205
Salas's Avatar
It was easy to DIY a finger lift for my 774 so I don't think it is not easy to DIY some damper interface ideas. Disco is very adept.
Old 2nd September 2009, 04:31 PM   #2206
Default OT
Ps I use ikea led ligth when I clean the vinyl ,same effect photoflash, a lot of dust
Old 2nd September 2009, 04:47 PM   #2207
nhinstruments
RCruz's Avatar
Hi Pete
It is not a pcb... I used it to guide me in a p2p riaa.
There is a last version and the measures are exactly as in the pdf (10 x 16cm)
Ricardo
Old 2nd September 2009, 05:30 PM   #2208
Cruz I mess a little with your design
Old 2nd September 2009, 05:33 PM   #2209
Salas's Avatar
Good guide for those wiring P2P. Useful.
Old 2nd September 2009, 09:23 PM   #2210
disco is offline disco  Netherlands
disco's Avatar
Also, be aware of a small offset introduced by the probes and wires. My Fluke 87 indicates 0,4nF without a component attached.
NB Nice tonearm Salas. Lots of praise still after so many years since introduction. Does your player have a heavy platter? The Dual 505 has a flimsy one
jaap
Simplistic NJFET RIAAHide this!Advertise here!
