Old 9th August 2009, 07:56 PM   #2141
RCruz is offline RCruz  Portugal
RCruz's Avatar
I am strugling with heatsinks....
Would this one be suitable for the shunt ? H S MARSTON - 05DN-00500-A-200 - HEAT SINK, 4.5°C/W http://pt.farnell.com/jsp/search/pro...jsp?sku=414189
Or two of those (one per mosfet) AAVID THERMALLOY - 6398BG - HEAT SINK, TO-220/218, 4.4°C/W
http://pt.farnell.com/jsp/search/pro...sp?sku=1213473
Ricardo
RC
Old 9th August 2009, 08:58 PM   #2142
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I prefer the second one per Mosfet, and R1=10R.
Old 9th August 2009, 09:12 PM   #2143
RCruz's Avatar
Thank you...
I believe I will have to review the shunt pcb layout... because of the fins in the heatsinks.
Ricardo
PS
I have R1 = 14r 1w
RC
Old 9th August 2009, 09:17 PM   #2144
Salas's Avatar
If its a big problem, use the first option, with 14R is surely enough.
Old 10th August 2009, 12:45 PM   #2145
RCruz's Avatar
I did a new layout so I can fit the individual heatsinks....
I calculated a led string dropout of 6,39v, using 14r I have ICCS with load = 174 mA
Using R1 = 10, I get 259mA... is this viable ?
Ricardo
RC
Old 10th August 2009, 12:47 PM   #2146
Audiofanatic's Avatar
Default PCB
Hi Jaap,
I can not PM you, your e-mail button is disabled.
Please contact me regarding your PCB's for the SALAS RIAA.
Thanks in advance.
Best regards,
Audiofanatic
Be nice to animals.
Old 10th August 2009, 01:37 PM   #2147
Salas's Avatar
Ricardo
Depends on the Vgs of the exact part, but with such Leds I would surely use the 14R so not to overshoot 200mA.
Old 11th August 2009, 12:06 AM   #2148
RCruz's Avatar
The green leds I used presented an average of 2,1v drop.
I now found some smaller yellow leds with 1,9 drop. Using 3 leds I get 5.7v... if my calculator is correct, admiting Vgs 3.4v, i can use R1=10r and get away with 190mA ICSS (230-40)... am I right ?
Ricardo
RC
Old 11th August 2009, 02:40 AM   #2149
Salas's Avatar
Yes if Vgs will be like that. You just measure the drop across the resistor in the end, and if its non usefully excessive, you make it higher R. I prefer the yellows slightly for best noise also. Its that the greens are easier to predict for those they don't match them.
Old 11th August 2009, 01:54 PM   #2150
RCruz's Avatar
I will match the leds before use so I will know vdrop in advance.
Using your formulae: ICCS=(Vdrop-VGS)/R1 I can find R1.
After building the shunt I will measure R1 drop and using ohm´law I will verify the current.
Looking very good already.
Ricardo
RC
Page generated in 0.40947 seconds (20.49% PHP - 79.51% MySQL) with 11 queries
