| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#201 |
Thanks for the reply. I shall be waiting for the results if it is not possible maybe another stage is required.
I have seen MadK's version and it looks promising. Regards, Jam |
#202 | |
I found most of the values C3 seems to be difficult... did you use several caps to reach 15.8 or 16nF ? How critical is this value ? Ricardo
RC |
#203 |
mulicaps polystyrene or pp the 15nf //1nf or add a small mica/styrene
my suggestion 15n RTX w/out small mica /styrene to fine tunning all PRP resistor , strategic position cartridge load/serie signal caddock132/riken/shinkor to taste
#204 |
diyAudio Chief Moderator
Nicoch46 covered it pretty well. And yes, that value is the most critical for HF balance.
#205 |
Ricardo, the best way is to select them with a C meter
It shouldn't be that difficult, as, according to my experience, 5% caps have generally an effective value slightly lower than the nominal value stamped on them. That means most probably a 15 nF cap is a 14,8-14.9 nF one. Once you find two right pieces, simply add two 1% (or selected) 1000 pF caps to get 15,8 nF. |
#206 |
or order matched caps for Riaa....
#207 |
Thank you for your answers.
So I must start with a precision 15n and fine tune with mica/polystyrene. And this is the most critical point for RIAA high freq acuracy. As I do not own a C meter I believe it must be done by trial and error. PS How is the cascoded version ? Better Bass? Regards Ricardo
RC |
#208 | |
It is possible to have high definition highly musical and dynamic sound with CD.. (After two years modding, my CD53 souns awesome). It is so good that now I need to upgrade my RIAA in order to balance things again. Do not take me wrong... I still prefer the wide sounstage and high precision low distortion sound of a good TT... but I need some more speed and transient power now. Note: Yesterday I implemented the DIY armaggedon with a 220/110v 160va TX in my premotec.... Lower noise floor.... better detail retrieval.... (Like adding a dedicated psu on the CDP decoder). I am amazed Regards Ricardo
RC |
#209 | |
Nothing dramatic, want to see what is really good, not merely different. Had to play for a week, all components are new. I wanna be fair and look well in to the issues, not go on recommending more complex stuff for no real reason. |
#210 | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.16405 seconds (70.28% PHP - 29.72% MySQL) with 11 queries |
