Simplistic NJFET RIAA
Old 17th April 2018, 10:31 AM   #17081
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Salas can't see the pics?
Old 17th April 2018, 10:53 AM   #17082
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
They are from a recent builder in a local forum so they didn't link to everybody maybe. Now I attached them to the previous post. Can you see?
Old 17th April 2018, 12:09 PM   #17083
Yes now I can see, thank you.
Old 17th April 2018, 03:55 PM   #17084
Pars is online now Pars  United States
Pars's Avatar
Thanks Nick, good to know for a baseline. I was using some crap phones and would guess that at the volumes I had it turned up to it would be ear-splittingly loud.
Iíll try to take D-Gnd voltage measurements for all JFETs tonight. I donít question the providence of any of them... 2SK369s are from teabag; 2SK170s came from a GB here years ago.
I do know that R13 is dropping 26.x Vdc across it on either channel.
Old 17th April 2018, 11:28 PM   #17085
patriz is offline patriz
patriz's Avatar
Originally Posted by Salas View Post
Yes it is but there can be tolerances to impose such a DC difference. Try with VR1 also. The key is to have almost the same signal gain between your two channels. Do you have any means to check that? Like a test record, function generator, oscilloscope, DMM on AC, sound card and FFT software, whatever. (You have to make make 1:100 voltage divider with 1k&10R resistors in a connector and shielded cable for driving clean low mV from lab gen or pc card)
I checked with an old analog scope and the signal looks the same in both channels.
Old 18th April 2018, 12:09 AM   #17086
Salas's Avatar
Good
Old 18th April 2018, 12:22 AM   #17087
Pars's Avatar
Yours is not a standard build for board and PSU so I can't tell for sure if there are issues right now. Normally its reported quiet even in MC mode without any special measures while just thrown around. Tell me your DC voltage on the drain of each JFET vs GND and if there's no doubt they are originals.
"Playing fine, noise is close to zero without a box."
I took some measurements:
Code:
board           1       2
Q1             8.42   8.41
Q3             4.54   4.32
Q4            11.51  11.28
Q5            11.42  11.24
Q6            23.61  23.36
TP1-TP2        3.25   3.47
Rail          35.51  35.22
I then looked at the outputs with a scope and with a DMM on AC mV. Scope showed a waveform:
board 1: 4.6 div @ 0.1V/div or .46V. Period was 8.3 @ 2mS, or 60Hz. DMM read 90mV
board 2: 4.5 div @ 50mV/div or .23V. Period the same. DMM read 45mV
Old 18th April 2018, 12:26 AM   #17088
Salas's Avatar
Will check those measurements out tomorrow
Old 18th April 2018, 03:26 AM   #17089
Pars's Avatar
Thank you, and thanks for the design and support! This thing certainly looks the business
Just as a further test, I powered this from my bench supply instead, and scope was showing the same thing. My scope is a Tek 465b, probably needs a recap, and my probes suck. They did however show me oscillation at 70Mhz in a Gilmore Dynafet I had previously never gotten working, so it isn't worthless...
Old 18th April 2018, 03:05 PM   #17090
Pars's Avatar
One other thing I didnít mention, but my workbench is 3 feet or so from my house electrical panel. It always has seemed noisy; scope probes go crazy when not connected to a ground, etc. I should try this somewhere away from this area...
Simplistic NJFET RIAAHide this!Advertise here!
