Simplistic NJFET RIAA
Old 3rd April 2009, 06:37 PM   #1571
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Ricardo, that question gets general answers by definition. A. Surely if a Fb cap helps also other op amps than original there, it is not the same value. B. What value or no capacitor, needs measurements for high frequency square waves and THD so to know. C. General tweaking practice info found mainly in forums of compensation and decoupling for certain popular op amps, may apply or not, but needs measurements for any different PCB and/or PSU design/components. D. If you still wanna tweak, trust your ears for the certain preamp with certain op amp substitutions, but never think that you really got an idea of what each op amp model can really do if surely properly implemented. The faster, the more rebellious.
Old 3rd April 2009, 06:47 PM   #1572
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Thank you Salas
I must read a lot before I do more modifications here.
I really need a good pre with loads of inputs.
Before commiting to the Riaa, I built a jfet buffer but did not finish the project because;
1st - it has output caps
2nd - I am not sure if my amp needs some gain.
Can a jfet buffer + caps sound better than a opamp without caps ? (I could live with less gain)
Ricardo
RC
Old 3rd April 2009, 06:48 PM   #1573
nicoch58 is offline nicoch58  Europe
mastering
Old 3rd April 2009, 06:51 PM   #1574
Salas's Avatar
Ricardo:
It depends on the quality level you have reached with op amps so to compare. Also on the needs of the main amp and speakers. My general practice is. A. If it sounds good, don't destroy it for checking out new quests. -} B. Make something from ground up if researching alternatives. Just my2c.
Old 3rd April 2009, 06:51 PM   #1575
use zen mod kit , optivol plus buffer without caps...cheaps too
Old 3rd April 2009, 07:22 PM   #1576
nhinstruments
RCruz's Avatar
Thank you so much.
I will start building from scratch.
Ricardo
RC
Old 3rd April 2009, 07:28 PM   #1577
nhinstruments
RCruz's Avatar
Where can I find Zen mod optivol ?
RC
Old 3rd April 2009, 08:15 PM   #1578
link
or order optivol(+minireg) and add the zen buffer ie JC buffer ,
forgot you need gain ? Salas can help ?
Old 3rd April 2009, 08:50 PM   #1579
nhinstruments
RCruz's Avatar
Yes
I need some gain.
I like the optivol idea, and Zenīs 1 buffer per output, but I need gain.
RC
Old 3rd April 2009, 08:54 PM   #1580
sure ?connect the phono direct to pw amp and play lower tracks
look at amp input.....
Simplistic NJFET RIAAHide this!Advertise here!
