Simplistic NJFET RIAA
Old 2nd April 2009, 04:13 PM   #1561
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Default Never ending rewardding process
New modification... this time I am in awe
I was loading the benz ACE (M) with a 2K21 RC55Y Welwin 0,1% metal film. sound was very good but I missed that final high freq attack and presence.
Based on previous experiments and using the feedback of the forum menbers I decided to use a 2K4 Shinkoh.
Now I am hearing Zappa´s Zoot Allures as never before..... the bass is very heavy but detailed, the highs are powerfull, detailed, with outstanding attack but never strident.
The best part is I can hear small info that was masket before, enhancing imagery, focus and stage size.
There is a sence of independency between the instruments I was not aware of before.
how can I explain these differences ? are shinkoh lower noise then metal film ?
Ricardo
PS:
This makes me remenber my B&O tangencial tonearm while using the saphire cantilevered MCC in my old defunct system. 20years ago
RC
Old 2nd April 2009, 04:17 PM   #1562
nicoch58 is offline nicoch58  Europe
there is some LSD on shinkoh
well done!
Old 2nd April 2009, 04:32 PM   #1563
nhinstruments
RCruz's Avatar
well done!
Incredibly I had just the same thought
RC
Old 2nd April 2009, 04:43 PM   #1564
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
He, he, tripping performance! Nicoch and I we were urging you for long...
Old 2nd April 2009, 11:21 PM   #1565
nhinstruments
RCruz's Avatar
Dr. Hoffman would be proud if he knew the impact of his discovery
RC
Old 2nd April 2009, 11:29 PM   #1566
Salas's Avatar
The Bicycle Ride
He knew, he died just yesteryear at the age of 102!
Old 3rd April 2009, 12:42 PM   #1567
Power amplifiers 100 to 400 plus watts are used to drive the tiny coils (one for each channel) in the cutting head. They’re like miniature speakers which instead of just moving air, push the stylus that etches the groove in your record. With 20 dB of treble boost, you can only imagine the beating that the cutting head takes from cymbal crashes and the like. The coils are helium cooled but still can reach 200 degrees Centigrade. A circuit breaker is used to prevent catastrophic destruction
Old 3rd April 2009, 06:17 PM   #1568
nhinstruments
RCruz's Avatar
Hi nicoch46
Well, maybe what I read before was related with the power amps themselves (D Amps?).
I have another question regarding the 101b opamp, It is rigged as a inverted voltage gain (+IN to GND) and the feedback resistor R1 seems to be a 100k. The input resistor seems 6.9k so the gain must be R1/R2=14.5.
Now the strange part is that there is a small cap in parallel with R1.
What should be the purpose of bypassing the feedback resistor with a cap ?..... Should I remove it ?
Sorry for the offtopic but I really need some advise.
Ricardo
RC
Old 3rd April 2009, 06:21 PM   #1569
Salas's Avatar
Its 99% a feedback compensation capacitor. Its related to the original op amp. Fixing it for best performance or even for oscillation without it. This is original designer's territory, and has to do with certain layout and PSU.
Old 3rd April 2009, 06:29 PM   #1570
nhinstruments
RCruz's Avatar
As I replaced the original NE5532 by a LME49720 (with uge gains in sonic quality), maybe I can remove them ?
Just looking at the circuit, it seems that at high freq the opamp would not have the same gain as in low freq...
RC
Simplistic NJFET RIAAHide this!Advertise here!
