Simplistic NJFET RIAA - Page 156 - diyAudio
Old 1st April 2009, 05:26 PM   #1551
with opa on output.....
Salas news from new baby ??
Old 1st April 2009, 05:41 PM   #1552
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Just did it.
While burning, I can report that it plays a little lowder and with some added bass.... Later I will post some pics.
Ricardo
RC
Old 1st April 2009, 06:08 PM   #1553
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You mean the Valve Itch?
Old 1st April 2009, 06:10 PM   #1554
yes yes
Cruz look here
Old 1st April 2009, 06:15 PM   #1555
Salas's Avatar
Heard them side by side. For background noise, the same as solid state. For Riaa EQ, same tonal balance. The tube one has more forward and juicy rounder SE tube amp style presentation. The Simplistic is more correct with more depth and detail. The tube one is better than the Bench cascode for comparing tube units. It does not enjoy a shunt yet, but a Maida. The Simplistic and the Bench have shunts. Maybe there is more in to it if with shunt, though I don't hear the Maida typical hardness on it due to its good PSRR being a Mu follower.
Old 1st April 2009, 06:17 PM   #1556
fine , just to know if we can live happy with sand
Old 1st April 2009, 06:21 PM   #1557
Salas's Avatar
The Simplistic is max bang for the buck. I know of people that will prefer the more enthusiastic Valve Itch style especially in rather dry systems. But under controlled, known variables, the Simplistic sounds more ''monitor'' without losing musicality. It remains to listen to the Itch with a HV shunt reg at a point.
Old 1st April 2009, 08:20 PM   #1558
RCruz's Avatar
yes yes
Cruz look here
I know.. I know
I am wondering if the space left from removing the MM Riaa will enable me to place a Burson V2 discrete opamp there... I know these do not need any output cap.
I did not give up my preamp project but I already spent a lot in building two pedja buffers with dedicated high spec +-15v psu that I did not finish
I must study the case intensely before moving on.
Actually I am amazed with the quality sound I am hearing in this new setup. (Maybe the 10k serial resistor was closing the sound a bit)
Ricardo
RC
Old 1st April 2009, 08:25 PM   #1559
Salas's Avatar
Yes, it was adding on source impedance, plus imposing its quality traits in series.
Old 1st April 2009, 09:33 PM   #1560
RCruz's Avatar
Cruz ,bass ?
I read a little on tone arm ,in general the unipivot have better air , bearings bass firm...12 inch aree better and have minor error traking
at fist nylon on 3009 was the upgrade on steel knife-edge ! after marketing go for steel.....try bronze....
This is a fine line of thought.. where can i find some suitable knife bearings ?
RC
Copyright 1999-2017 diyAudio
