Simplistic NJFET RIAA
Hi everyone. I have a question about the signal path resistors. I have the notion to mount signal resistors flush to the board, while leaving the others some gap to dissipate heat.
If that is a good way to approach it, am I correct that all rhe signal path resistor are R1, R2, R3, R4, R5, R8, R10, R11, R12, R13, R14, R15, R21, and R22?
Ufsp is really special,so I decided to explore how it sounds with a very good step up transformer in front of it.so,I decided to go the Japanese way with Kondo audio note SFz,which is adjustable to 34 and 20 db gain.My cartridge is Dynavector xv1t,which is 24 ohms with 0,35mv output.long story short,amazing combination.it seems I haven’t met ufsp ‘s limits,after so many years,still surprises me.A big Bravo to Salas.
Reactions: jazzbear and Salas
