Simplistic NJFET RIAA - Page 149 - diyAudio
Old 26th March 2009, 11:55 PM   #1481
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Will do proper AB now that it got well broken in. Planning in the next few days. Will post.
Old 27th March 2009, 12:10 AM   #1482
Salas's Avatar
Originally posted by RCruz
When you have time, please comment on the drawing... I must be sure there are now flaws this time.
I think that you got all JFETS facing the wrong way.
Old 27th March 2009, 12:16 AM   #1483
Salas's Avatar
Unless you actually show the underside in the pdf.
Old 27th March 2009, 03:26 PM   #1484
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi salas
I forgot to tell you this is the underside of the board.
Apart from that issue, do you agree with the overall schematic ?
RC
Old 27th March 2009, 03:42 PM   #1485
Salas's Avatar
Yes it looks OK. I would make provision for an alternative general earthing point to star at C2 earth node too, just in case. Also try a 1k8 R20 on your current phono to see if it stabilizes easier.
Old 27th March 2009, 05:19 PM   #1486
nhinstruments
RCruz's Avatar
Thank you Salas
Increasing R20 lowers voltage in Q5.... will it affect sound quality ?
What should I expect ?
Should I have more than 1 GND point ? my actual setup has one star gnd where all gnd´s go.
RC
Old 27th March 2009, 05:29 PM   #1487
Salas's Avatar
I meant to have one point still, but different take off alternatives just in case. Regarding R20 I thought it may help you if there is less voltage across Q5 regarding the noises you get. Since nobody else ever got the noises, I don't know more. Its a proposed experiment. You will tell if it helps the noises you get during warm up or if it changes the sound. The current remains the same.
Old 27th March 2009, 05:39 PM   #1488
nhinstruments
RCruz's Avatar
I believe noises come from bad solder joints... my pcb is now a real mess.... that is why I want to rebuild everything.
If nobody else reported any issues, maybe I should stick to your original design.
Another pertinent question:
I am now using 2K21 RC55Y Welwin 0,1% metal film for cart loading and really think this is the perfect value.
I would like to try Shinkoh in there but do not know if I need to change the value.
I would really apreciate your comment.
Ricardo
RC
Old 27th March 2009, 06:04 PM   #1489
Salas's Avatar
Normally Shinkoh gives the most grain free and organic rendering there. But not heavy at the same time. I would keep the value. Only thing is that with Shinkoh you can normally go higher in value before you get some ''pinch'' as with other resistors.
Old 27th March 2009, 07:49 PM   #1490
nhinstruments
RCruz's Avatar
Can you please suggest a good quality DMM ?
Myne is able to read capacitances but I always get lower values than indicated in the caps. (For instance, K72-6 0.047u reads 44.6nF)
ERO 620pF reads 599pF....
Mundorf 4.7uF MKP reads 4.4u ...
RC
Copyright ©1999-2017 diyAudio
