Simplistic NJFET RIAA
Old 28th September 2008, 08:21 PM   #131
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by salas
First diy 1981, B110+T27...
Wasn't the Daline was it? (HiFi News and Record Review, sometime 1975). This was my 2nd DIY Speaker set.
Old 28th September 2008, 10:10 PM   #132
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No, it was from Sound & Hi-Fi Greek magazine. About 10lt closed, Acoustic Butterworth crossover with no baffle step. Was to be combined with a B139 sub. But I made a bigger one, BR with a double coil Audax 30cm (12inch), sensitive enough unit and a central passive crossover at 170Hz.
*Nicoch46, I am tuning a special 40dB version for the DL-160. Will show soon.
Old 29th September 2008, 05:44 PM   #133
Salas's Avatar
Default High MC out version
This is the version that the gain, loading and sound is the best I could find for high output MC. I used the Denon DL-160 as a standard. Sounds really neutral as a combination. In case someone needs some more gain, the Rsource 50R can go down to 33R. I was more than OK with 40dB and the Denon, that looks like producing more than its nominal 1.6mV to me, rather something like 2mV+. But I have sensitive speakers too. The 120nF coupler can be 100nF. The Cout is arbitrary value. See the Salas MC comments on the page before for that.
So we have 3 options: The MC Salas RIAA for 0.5mV, the same can be modified with a 1st stage Rsource bypassing capacitor as shown on its schematic (previous thread page) for +6dB and 0.2mV carts, and this last one with low PSU, and a couple of resistor value changes for high output MCs, 1.5mV-2mV or 1mV with 33R Rs. All 3 options are well tuned, checked, and thoroughly auditioned. Using a variable regulator for B+ someone can easily modify the MC version for high MC in 10 mins with a soldering iron.
That's about it.
Old 29th September 2008, 05:48 PM   #134
Salas's Avatar
Here is how the Denon DL-160 measures through the high MC version on Telarc Omnidisc pink noise L+R track.
Old 29th September 2008, 06:12 PM   #135
nicoch58 is offline nicoch58  Europe
Wow!!
You use 20 v for jfet sweet spot ?
no problem for me, variable psu 18-26 v
yes 2,2mv!
Old 29th September 2008, 06:16 PM   #136
Salas's Avatar
Yes sweet spot hit, for best stability, no leakage and best THD.
You still have your DL-160? 1k loading worked best in this combination too.
Old 29th September 2008, 06:25 PM   #137
dl-160 are on rega ,1k not close the sound stage?
with mad_k I have 23,5k ,with 3k close in ,great difference ....
Old 29th September 2008, 06:31 PM   #138
Salas's Avatar
In my case it worked more open and correct @ 1k. It tends to spray HF distortion and more noise with high RL. My guess is that in non neutral systems with a bit of bass boom & beaming HF, high RL compensates and sounds ''open''. But I will listen again with 15k after more break in, maybe my impression is going to change.
Old 29th September 2008, 06:37 PM   #139
Salas's Avatar
...Also mad_k has a different distortion profile. More 2nd Harmonic. It also will produce much output with the Denon, and I don't know if it starts saturating with 2nd H above normal, tending to sound thicker.
Old 29th September 2008, 06:55 PM   #140
my supravox don't do thorsten L. project....
Simplistic NJFET RIAAHide this!Advertise here!
