Simplistic NJFET RIAA
Old 11th January 2015, 05:50 PM   #13971
orelli is offline orelli  Italy
Send a message via AIM to orelli Send a message via MSN to orelli Send a message via Yahoo to orelli
Originally Posted by Salas View Post
Better vary R20 instead. Keep the cap.
where is R20?
Old 11th January 2015, 05:53 PM   #13972
Merlino, are you running single ended or balanced?
Old 11th January 2015, 05:55 PM   #13973
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by orelli View Post
where is R20?
In his particular simulation. Meaning his source resistor for depletion Mosfet. Can vary that CCS current.
Old 11th January 2015, 05:55 PM   #13974
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
where is R20?
R20 is the source resistor in the new CCS (in my simulation it is numbered R20)
RC
Old 11th January 2015, 05:57 PM   #13975
Salas's Avatar
Originally Posted by merlin el mago View Post
Really really a piece of cake and a pleasure making the FSP, plenty of power, a lot of detail, a new beast is born to let us enjoy our vinyl treasures.
Old 11th January 2015, 05:59 PM   #13976
Salas's Avatar
Run FFT with input signal good for -10dB output which is the normal for this. I will tell you if it ties with reality bcs I had run real FFT in many builds.
Old 11th January 2015, 06:00 PM   #13977
nhinstruments
RCruz's Avatar
It will reject better the rail but it will inject some extra current noise too. Listen carefully for tradeoffs.
Will try a noise analisys before implementation.
Can we get lower noise with bjt CCS ?
RC
Old 11th January 2015, 06:02 PM   #13978
Salas's Avatar
Not sure, it depends on rbb' and bias current. You would need genuine low noise BJTs that can take the dissipation also.
Old 11th January 2015, 06:56 PM   #13979
nhinstruments
RCruz's Avatar
Yes... True... I simmed it with common bjt's that can not take the heat.... just for fun
RC
Old 11th January 2015, 07:55 PM   #13980
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Ciao Orelli, now SE but due to the high SQ I'm thinking to go balanced in the future.
Simplistic NJFET RIAAHide this!Advertise here!
