Simplistic NJFET RIAA
Old 9th August 2014, 07:40 PM   #13151
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by stajo View Post
I also think this is how I will arrange R1+ Rx1-4
47 47 18 18 6,8
This gives me those combinations:
47//47 = 23,5
47//18 = 13,5
47//47//18 = 10,2
47//18//18 = 7,55
47//6,8 = 5,94
47//47//18//6,8 = 4,08
47//18//18//6,8 = 3,58
47//47//18//18//6,8 = 3,33
And 47 alone ofc. Thoughts about that?
That's a very nice load range to listen to the Dyna 10X5.
Old 9th August 2014, 07:45 PM   #13152
Salas's Avatar
Polaris Electronics.
Ok, I'll arrange it like this:
Ch1 Q4 8,44 Q5 7,14, Q6 8,27
Ch2 Q4 8,56 Q5 7,71, Q6 8,72
tomorrow
I would swap the Ch2 Q5, Q6 to Ch1. Since Ch2 Q4 will drop a bit more than Ch1 Q4 from B+ not to continue the trend.
Old 9th August 2014, 07:49 PM   #13153
stajo is offline stajo  Sweden
Right, thanks. Q5-6 is a follower just adding current, not gain right?
Old 9th August 2014, 08:06 PM   #13154
Salas's Avatar
Right. So it will drop some voltage across R11 analogous to Q5 IDSS.
Old 10th August 2014, 07:47 AM   #13155
Just found out that I had ordered some extra K170 from Mike. Those had better coherence to my measuring method. Unfortunately none in the Q4 region.
So if I arrange it:
Ch1 Q4 8,44 Q5 7,71, Q6 8,72
Ch2 Q4 8,56 Q5 7,14, Q6 8,27
Is there any reason for me to change for example Ch 1 Q4 from 7,71 to a 7,14?
The 9ers is ordered as a quad. I dont remember what project I had in mind but maybe I should keep that as a quad and not use it as Q6es.
Old 10th August 2014, 01:04 PM   #13156
Soldered up and tested the PSU meanwhile. 41,5 AC sec unloaded, about 49,5 VDC@127 mA (390R dummy) and 48,5@145mA (335R). Might eventually sneak up to the 50 depending on the final setting. Am I clear with that or do I need to us the RD/Link?
Old 10th August 2014, 01:08 PM   #13157
R.I.P.
What output voltage do you get at maximum supply voltage as the input?
regards Andrew T.
Old 10th August 2014, 01:18 PM   #13158
Do you meen unloaded, with just the C and the bleeders?
Old 10th August 2014, 02:41 PM   #13159
R.I.P.
yes, if the supply rail fuses blow, or you turn the quiescent current right down, or you disconnect one amplifier and test the other one.
regards Andrew T.
Old 10th August 2014, 02:51 PM   #13160
Aha. I dont have the boards all populated yet. Still figuring a few LCD and FET measures out before soldering. Later
Simplistic NJFET RIAAHide this!Advertise here!
