Simplistic NJFET RIAA
Old 6th April 2014, 10:01 PM   #12441
pellesmil is offline pellesmil  Norway
pellesmil's Avatar
Running the Folded pasive tonight
23pos Seiden w. Takman Carbon + 10k Z-foil
Damn this Riaa sounds good
Doors at 13 O´Clock volume, perfect for a sunday night
Old 6th April 2014, 10:32 PM   #12442
skouliki is offline skouliki  Greece
skouliki's Avatar
Excellent choice of record pellesmil
Today for sake of experimentation i thought of adding 2 1000uf Rifa PEH169 to the PSU right after the rectifier, forming a CRC filter. 1000uf-1ohm-4700uf
I may be doing more harm than good because these caps connect to the board with wires. Havent done any serious listening session yet, and the PSU looks a bit silly
Old 7th April 2014, 04:05 PM   #12443
pellesmil's Avatar
Sweet
have you settled for 1 ohm?
roughly you would have about 100mv ripple in that setup
Going to about 15 ohms decreases the ripple to aprox. 16mv
Per
Old 7th April 2014, 04:17 PM   #12444
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Per, what phono(s) you had before?
Old 7th April 2014, 04:56 PM   #12445
pellesmil's Avatar
-Some Norwegian rarities (Doxa)
-DV P-75mkII
-AAPP 2006 edition (Torstein Lorch) for a brief while
-Present RIAA
Old 7th April 2014, 05:12 PM   #12446
skouliki's Avatar
Originally Posted by pellesmil View Post
Sweet
Per
No i havent really settled to specific values, just using what i already had in hand. Salas if i increase the value of R to 15ohm , how would that affect the reg down the line?
Old 7th April 2014, 05:38 PM   #12447
Salas's Avatar
The more Ohm the more of a time cycle the more of a filter. Slower to charge the last capacitor but cleaner. Given the draw is constant there is no dynamic current demand so it should be a positive move.
Old 7th April 2014, 10:46 PM   #12448
skouliki's Avatar
Thanks Salas
Old 9th April 2014, 06:55 AM   #12449
alexkosha is offline alexkosha  United States
alexkosha's Avatar
Guys, does anyone familiar or used these resistors?
Can't find any info on internet.
They are about 10-12 mm in length and 5 mm in diameter. Black glossy plastic and white-silver printing
PTF60
10K0
7843
Old 9th April 2014, 07:03 AM   #12450
Salas's Avatar
They look like older line Vishay-Dale low ppm precision parts.
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2017 diyAudio
