Simplistic NJFET RIAA
Old 11th March 2014, 04:47 PM   #12231
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by dirkwright View Post
Well, just because very few use an input buffer for MM phono preamps, doesn't mean that it shouldn't be used. Most commercial designs are made at the lowest cost.
This effect is not seen with triodes, for example, but it is slightly evident with an EF86 input. I assume there is significant input capacitance on JFETs that is interacting with the inductance of the cartridge to produce a resonance, but I don't know that for a fact.
To each their own, obviously. I'd rather make something that is far and above better than anything I can buy, even if it's advantages are only evident on test records. Otherwise, I'd just buy someone's phono preamp and be done with it.
Its all about Miller. Tubes should have less total parasitic capacitance than large geometry low noise JFETs to be gain multiplied. But cascoded JFETs with Rs should control much of it. When simulating two parallel cascoded JFETs with 45dB gain and minimal Rs vs. one cascoded JFET with 25dB gain and much bigger Rs there should be less bumping with same inductive source than just proportional to gain due to half the initial parasitic and much more local feedback provided by its source resistor. So that's a check point on what the simulator shows. JFET models are usually just indicative on many parameters. SPICE has much better BJT models. In any case 1 meter of TT cable should show about 100pF. Add to that ~70pF from a configuration like in FSP's MM mode, its still staying within spec of what most MM carts manufacturers would recommend as minimum for loading. And there is the resistive load value also to can tweak favorably.
Old 11th March 2014, 07:07 PM   #12232
rclourenco is offline rclourenco  Portugal
Default My finished Folded
Just finished my folded implementation and couldn't wait to turn it on.
After bench testing, trim setting and stabilization, all was well and working.
So, next step, connect it to the system, first impressions are very good, very silent (in fact dead quite), I will keep on burning it up, and do some tweaking. I just bought a Dynavector 10X5 but it will only arrive next week, then I will try and play around C2Y and so on.
The PWS is based on 2 separate EI iron 50VA/2x18V transformers (German make and very quite mechanically), these are connected to a bridge built around IXYS rectifiers, all snubbed by an RC array. Filtering is done through 2 BHC 4.700uF each. Umbilical cord as specified on the Folded text, using Neutrik 4 pin connectors.
RIAA itself is built around the commonly used parts on this thread, like Mundorf, Elna, Vishay, Obbligato and Silver Mica caps, some PRP and Mills resistors + Takman Rey, and finally Vishay naked for R1 and R14.
Sorry for the poor photo quality, but had no time to take better pics.
Thanks to all involved in making this possible.
I am very happy
PS - The TT is based on Lenco platter, with PTP 5 and PTP bearing (very good), plinth is locally CNC curt and Epoxy covered and buffed by me. Tone arm is the wonderful The WAND in its latest Plus+ implementation. For now Ortofon RED2M, just waiting for the Dyna (nice its also red so my wife won't complaint)
Old 11th March 2014, 07:44 PM   #12233
Salas's Avatar
Excellent assembly work as always from you. Congratulations, happy listening, and keep us posted.
Old 11th March 2014, 07:53 PM   #12234
quan is offline quan  Australia
Nice set up. Enjoy the music.
Quan
Old 11th March 2014, 08:37 PM   #12235
Turbon is offline Turbon  Sweden
Turbon's Avatar
Yes, very nice indeed! Lovely Lenco
Old 12th March 2014, 03:52 AM   #12236
alexkosha is offline alexkosha  United States
alexkosha's Avatar
I am very happy
It is really, really nice.
Can you be more detailed about PSU part.
How did you snubbed it? What values? Have you used Hagerman's snubbers calculation formulas?
Old 12th March 2014, 11:18 AM   #12237
Turbon's Avatar
Hi.
Been thinking (bad sign ).
As the FS is one of my devices I'll ask here.
What if I remove the output caps from all of my devices and only have 2 at the input of my mezmerise?
This to concentrate the need of the best parts in my view to one place.
Of course different devices may do better with different output caps... Or?
Old 12th March 2014, 11:53 AM   #12238
Salas's Avatar
It has been done before in this thread in a single box preamp (phono/line buffer/active crossover?) taken a step further by substituting the phono's last stage with a switched input DCB1 stage, only coupling with 100nF from the phono's second stage drain pin. When having no pot in between. On point to point matrix board custom diy of course. Your alternative scheme is also doable. The phono section will no more stay individual and the DCB1 will be not capacitor free for any input anymore of course.
Old 12th March 2014, 12:48 PM   #12239
Turbon's Avatar
"the DCB1 will be not capacitor free for any input anymore of course"
Right, but the rest will have no caps on their outputs . So the gain would be that I as a maximum would need 2 very top line caps in the Mez instead of 12 in the devices
Old 12th March 2014, 02:34 PM   #12240
Salas's Avatar
In a customized & fixed full system architecture makes economical sense.
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2017 diyAudio
