Simplistic NJFET RIAA - Page 1164 - diyAudio
Old 15th January 2014, 06:39 AM   #11631
Originally Posted by Turbon View Post
Wouldn't using any kind of terminal add one extra interface vs soldering the cable directly to the board?
I never use the terminals. A lot off plastic and magnetic screws.
Old 15th January 2014, 08:02 AM   #11632
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Erlend Sæterdal View Post
Thoose wirewound resistors can cause oscillation. Once I had that problem with a Riaa.
Not here if not used as gate stoppers. Not in the load and Riaa sections certainly. No loop NFB, no gate stoppers other than in the regs MOSFETs.
Old 15th January 2014, 09:22 AM   #11633
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by alexkosha View Post
I remember we discussed crimp connection here. Please see attached pictures and let me know if this is what we considered as an optimal way to use wires with screw terminals. I do not want to use WBT ($1 a piece is quite crazy) since min size is 20 AWG with no isolation. I have up to 32 AWG with insulation collar perfect for my RG-174 coax now and all PSU power wires.
That is exactly what I use.... perfect
RC
Old 15th January 2014, 12:10 PM   #11634
skouliki's Avatar
Just read the comments from Erlend about your phono versus the Accuphase beast. Congratulations for your design Salas!
Im also very happy i got to build an extreme value-for-money phono
Thanks for sharing this!
Old 15th January 2014, 12:25 PM   #11635
Salas's Avatar
Erlend did not listen himself to tune it up yet, from the soldering iron to the reviewer with Soviet MKT output caps and 40yrs old PSU electrolytics, yours is in a more sophisticated phase.
Old 15th January 2014, 12:32 PM   #11636
Salas's Avatar
...But he has plan to retaliate.
Old 15th January 2014, 12:40 PM   #11637
skouliki's Avatar
Mine requires a bit of polishing too = better output cap. I better start saving !
Old 15th January 2014, 12:48 PM   #11638
Salas's Avatar
Did you review your TT set up in detail by now? Platter leveling, VTA, VTF, overhang, tracking error null points, TT support... There could be hidden potential there from your last set up with older phono. Some Dyna 10X5 in the future will be the decisive step ahead from the DL-110 nonetheless.
Old 15th January 2014, 12:50 PM   #11639
skouliki's Avatar
Im currently looking into protractors. Downloaded the guru protractor and plan to use it in a day or so. Do you know any protractors that would work really well for the dl110?
Old 15th January 2014, 12:55 PM   #11640
Salas's Avatar
I just use the HFNRR test disc protractor which is a white carton disc accurately punched in the center. Nothing fancy.
Copyright ©1999-2017 diyAudio
