Simplistic NJFET RIAA - Page 1114 - diyAudio
Old 19th December 2013, 10:19 AM   #11131
Originally Posted by RCruz View Post
Screw terminals are ok if you terminate the wires properly with Cable End Sleeves like those from WBT or others less expensive.
Just terminate the cables and screw them tight..
Originally Posted by alexkosha View Post
My terminals are ex-military and silver plated.
Found them in local surplus store.
They are very stiff and should be no issue with them ...
I always use solder (BWT currently) to finalize cable ends.
Never used any sleeves till now.
BTW, for correct sleeve installation you need to use special crimp-pliers.
I do not have it yet....
You don't need a crimper.
A close fitting thimble over the stranded wire ends will be crimped when the screw terminal is turned down hard.
The cross-sectional area of the thimble will be bigger than the cross-sectional area of the cable. That equals lot's of air/gas between the wires.
Screw down on the thimble and the area inside the squashed oval is less than the circular cross-section. Screw down hard and the kidney shaped cross-section inside the deformed thimble is now less than the cable cross-sectional area. The wires get deformed and you end up with "gas tight" joints between the strands and between the thimble and the wires and between the thimble and the enclosing terminal.
It's the "gas tight" that gives the excellent long term electrical connection.
And a thimble replaces the need for soldered ends and is FAR BETTER than soldered ends.
I don't have any thimbles. I wish I did have a range for all my cable sizes. I would use them.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th December 2013, 10:30 AM   #11132
stajo is offline stajo  Sweden
As there is a discussion about silent components here I wonder if anyone has suggestions on a quite resistor in the 200-250K range. I find only bulk foils up to 100K. (Anode load for 12AX7 so a bit OT but applicable on the subject maybe)
Old 19th December 2013, 10:34 AM   #11133
metal film is very good.
Not quite at the lowest levels of an extruded metal, but very close.
Extruded metal includes foil and wire and similar.
regards Andrew T.
Old 19th December 2013, 10:39 AM   #11134
Turbon is offline Turbon  Sweden
Turbon's Avatar
Originally Posted by nezbleu View Post
I got some nice cases last time from a place in China, and the delivery time was surprisingly short, the quality pretty good, and the prices amazing. Similarly, I already got some of those aviation 4-pin connectors from a Chinese PC-mods place at crazy low price.
Would you share the links to these vendors? I'm waiting for C3/C4, 2sk170bl's, trafos, Welwyn 0,1% resistors and Vishay VAR's for RIAA and R1/R14. Then a test in free air and decide boxing...
Old 19th December 2013, 12:10 PM   #11135
Mayby https://www.elfa.se/elfa3~eu_en/elfa...9-59&toc=20066 is my friend? Anybody tried?
Old 19th December 2013, 12:27 PM   #11136
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Excellent resistors, I have used such many times. Clean and no harshness. Analog_sa has like those on his loading positions Rx in FSP he showed if you look carefully but in 0.25W maybe 15ppm version RCY.
Old 19th December 2013, 12:31 PM   #11137
Turbon's Avatar
Originally Posted by stajo View Post
Please test and give your verdict :-) I had my eyes on those too...
Old 19th December 2013, 12:40 PM   #11138
skouliki's Avatar
Boards are now ready for powering up!
I used polystyrene ERO kp1834 5% for the treble RIAA cap plus trim cap which gave me a value of 15.18nf and 15.15nf. Readings where taken with a very cheap DMM so i know that are not accurate. If the sound is weird i will replace them with mkp1837 caps as per guide. The smd resistors are TNPW and r13 is Royalohm 1% 2w MF 50ppm. Output cap is JB JFX which are a pleasant surprise considering the fact that they are really cheap. I tried these as coupling caps in my AD1865 dac, and they outperformed Mundorf white MCap, Solen and Κ73-16. So until i can afford Mundorf supreme these caps will suffice.
Hoping of listening to music this night and not debugging!
Old 19th December 2013, 12:46 PM   #11139
Salas's Avatar
You probably got one of the most imaginative mix of components there. Looks well done also. Happy testing and let us know.
Old 19th December 2013, 12:47 PM   #11140
Salas's Avatar
P.S. That is the 43dB setting, yes?
Copyright 1999-2017 diyAudio
