Simplistic NJFET RIAA
Old 16th February 2009, 06:18 PM   #1031
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
A closer view of the MSR.... (Mighty Salas Riaa)
There is a lot less compression, the instruments are more individualized, soundstage is good and there is a lot more detail.
I hear previously hidden parts of the recordings with great detail.
Highs (guitar chords, metal platters in the drums) are now becoming very strong and detailed (lifelike).
All this after 1/2 hour playing.
RC
Old 17th February 2009, 12:24 AM   #1032
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Congratulations! 50 hours to go! Keep on spinning the black honey!
Old 17th February 2009, 08:06 AM   #1033
nicoch58 is offline nicoch58  Europe
good work !
now tray to bypass the pre ,you need a decent pot ...alps suck, at low level there is 3-6db tracking error beetwin channel and some THD for delicate mechanical contact
order the cheap optivol from ska-amp ,change the two series resistor with tantalium ,a lot better then normal pot
PS
I will came back with my shunt ,after solved my family problem....
Old 17th February 2009, 09:06 AM   #1034
nhinstruments
RCruz's Avatar
Originally posted by nicoch46
good work !
Do you mean I can use only a pot between the Riaa and the power amp ?
Ricardo
RC
Old 17th February 2009, 09:28 AM   #1035
kstlfido is offline kstlfido  United States
kstlfido's Avatar
Ricardo-
I run straight in. Still don't have a volume control- so listening is limited to daytime. I believe you have the output buffer so it should work well straight into an amp.
I intend to build one of those ldr attenuators (lightspeed thread); I might need to buffer it's output... Straight in, mine is about as loud as I need. But YMMV...
-Kent
Old 17th February 2009, 02:06 PM   #1036
Yes ,I have used straight in without problem ......
If you dont have sufficent gain add a buffer, JC or Pass b1
Old 17th February 2009, 02:12 PM   #1037
HI kent my suggestion is to order two optvol if you want tray the lightspeed, fom me better use the series element as normal resistor ,and play with brand for fine tweak ...
you can tray for we?
Old 17th February 2009, 06:45 PM   #1038
nhinstruments
RCruz's Avatar
Hi nicoch46
Excuse my ignorance but what is a JC buffer ?
Ricardo
RC
Old 17th February 2009, 06:46 PM   #1039
Salas's Avatar
Hey Ricardo, how is your auditioning going?
Old 17th February 2009, 06:51 PM   #1040
Salas's Avatar
Originally posted by RCruz
Hi nicoch46
Ricardo
Means a John Curl buffer. But your RIAA is already buffered so it will not lose from its own gain. And a further buffer after the pot will not add gain either. It may interface the pot nicer, but that is all. The main thing is if you get enough drive for your habits to the main amps, speaker, room, system.
Simplistic NJFET RIAAHide this!Advertise here!
