Simplistic NJFET RIAA - Page 102 - diyAudio
Old 12th February 2009, 01:22 AM   #1011
iko is offline iko  Canada
iko's Avatar
Ricardo, I put a .15u russian cap in the interstage coupling position, and then another one on the output, in parallel with two 1u (sprague pio).
Hope it goes well for you.
Old 13th February 2009, 09:32 PM   #1012
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Salas
Can I use a 16v cap in C6 ?
What is the maximum voltage there ?
Almost done...!!!
After all the board does not have a common GND between channels.... Lee left the copper all around the circuit... like a mask... should I ground this "virtual gnd" ?
Ricardo
RC
Old 13th February 2009, 09:45 PM   #1013
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes you can, the Zener is for 8.2V there. So C6 can safely be 16V.
Actual ground traces I would connect from phono channels to the shunt's reg out GND like a Y. And from there, with one cable to chassis. The masks I would connect locally to the ground traces where the cables to reg GND take off. Off course all this may change if you face some GND loop (I wish not).
Photos, first impressions etc. I don't have to remind I guess...
Old 14th February 2009, 09:51 AM   #1014
nhinstruments
RCruz's Avatar
Thank you Salas
My plan was to build a central star GND and then route there all the following GND five wires:
Shunt - one wire to star
Riaa (both left and right GND plus another wire for the screen) - three wires to star
Output rca - two wires to star
I plan to solder the input rca directly to the riaa board.
Is this a good idea ?
Ricardo
RC
Old 14th February 2009, 10:00 AM   #1015
Salas's Avatar
Yes its a standard star. So it must be good. You must start with something. If you don't get buzz, you will be practically OK. Make it so we know. Final countdown? When ready?
Old 14th February 2009, 10:27 AM   #1016
nhinstruments
RCruz's Avatar
I believe tomorrow I will have everything ready for testing.
I will have to compromise in this first stage because I do not have a metal case.
RC
Old 14th February 2009, 10:29 AM   #1017
nhinstruments
RCruz's Avatar
Underside....
RC
Old 14th February 2009, 03:10 PM   #1018
Salas's Avatar
I hope that the PIO in the RIAA filter is in good tolerance...
Where is your C3? This one is the most RIAA critical. Must be 15.8nF-16nF measured and matched if possible.
Old 14th February 2009, 08:34 PM   #1019
nhinstruments
RCruz's Avatar
Here you have a pic of C3 ... it reads an incredible +-0.3%
RC
Old 14th February 2009, 08:37 PM   #1020
nhinstruments
RCruz's Avatar
And another of C1.... looks very small to me
RC
Copyright 1999-2017 diyAudio
