Simplistic NJFET RIAA
Old 16th September 2013, 08:31 AM   #10111
massimo is offline massimo  Italy
Originally Posted by nezbleu View Post
I don't think 1837s are film and foil. They are metallized film. I have been trying to find some Wima FKPs for this because they are film and foil.
That said, the Vishays are very good and have a great reputation.
Correct. The Film&Foil Vishay belongs to the KP1830 series, but while you can find the 15nF, 47nf doesn't exist. Same for Wima's Film&Foil FKP2 5mm pitch, which can be green (NOS) or red (new production).
Old 16th September 2013, 08:44 AM   #10112
keantoken is offline keantoken  United States
keantoken's Avatar
The Kemet R73 are film/foil and have great treble, compared to Vishay MKP. Kemet is the company that acquired Rifa. The Rifa PFR (foil) series can still be bought from Mouser, but you have to play with the search to find them because they aren't entered into the site correctly.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 16th September 2013, 09:10 AM   #10113
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Maybe a a compact size raw DC rail filter added in the phono box sitting between the umbilical and the channels DC input connectors can bring benefit beyond some passive parts details.
Of course a very balanced design between isolation performance and low output impedance is Keantoken's. Recommended for a before & after test to the handier Folded Simplistic near future builders.
Old 16th September 2013, 12:29 PM   #10114
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
What is Keantoken's (phono stage)?
Old 16th September 2013, 12:33 PM   #10115
Salas's Avatar
Its a capacitance multiplier DC rail filter. Look at his signature ink.
Old 16th September 2013, 01:24 PM   #10116
Joshua_G's Avatar
Do you mean using the capacitance multiplier before the Salas Shunt, or instead of it?
Old 16th September 2013, 01:37 PM   #10117
Salas's Avatar
The DC input connectors on the FS PCB are the shunt regulators inputs. Any filter between them and the main PSU box umbilical consists DC pre-filtering. A filter does not regulate, only follows its DC input plus some insertion drop. Different jobs.
Old 16th September 2013, 02:19 PM   #10118
Joshua_G's Avatar
Thanks.
Old 16th September 2013, 04:24 PM   #10119
spinning wheel is offline spinning wheel  Netherlands
what exactly do we want to suppress ? charging pulse .. HF garbage ?
THX
Paul
Old 16th September 2013, 05:15 PM   #10120
Salas's Avatar
Whatever it can be produced in the rectification or it can intrude the long power cabling.
In my prototype I could not make it catch a GSM phone buzz and I never trimmed its TPs again not noticing intermittent noises, neither a tonal nor an image shift, since I closed its lid in August. That is stock with basic PSU as it is described in the guide.
This does not mean that other builders will not aspire to more elaborate main PSUs or will not want to try some add on filter, whatever.
Freedom of personalized packaging and configuration, favorite passive parts etc. is part of the joy of building DIY audio.
Simplistic NJFET RIAAHide this!Advertise here!
