| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#1001 |
I also want to extend to Salas my thanks for sharing this project. I've been lurking on this thread for quite a while now, and am definitely planning on implementing this phono stage.
Great work! Terry |
#1002 |
Soon I will join the "experienced" ones
All resistors in place (had to deviate a little from Lee´s layout to acomodate the uge 1M kiwame). Promising..... Just a little question.. I know my version has a buffered output and my intention is to do the following path: Riaa -> 50k dual log pot -> Pedja Buffer -> Meridian 103 power amp. Is this a good idea ? I just want to avoid the 101b opamp output stage but I am a bit confused.... Regards Ricardo
RC |
#1003 |
diyAudio Chief Moderator
The Pedja has a better chance of sounding more transparent than the 101b I guess. But you just have to compare. Maybe you will need 101's gain. I would set up phono-101-103 first. After all has burned in, and familiar with, I would listen VS phono-pot-Pedja-103.
#1004 |
Go Ricardo, Go!
Got the k40y-9 PIO russian caps today, in the .15u value. They're burning in |
#1005 | |
#1006 | |
Firstly I will feed the Salas Riaa through the 101, maintaining the 101 gain. After that I will build a dedicated pre based on the pedja. Nevertheless I am glad to know you did not find any issues in using riaa + pot + buffer. Ricardo
RC |
#1007 | |
What value are you using for C1 ? I have a russian k40-9 0.047 there but looking at the photos previously posted, these seems so small Ricardo
RC |
#1008 |
C1 you mean the one that couples to the second stage?
#1009 |
If you mean that one after the RIAA that goes to the 1meg to earth and second JFET's gate, then 47nF to 150nF will do. Center is 100nF. The response will still go subsonic with all of the above. No problem.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| jybe |
| Page generated in 0.13535 seconds (58.28% PHP - 41.72% MySQL) with 11 queries |
