Need new drive belts for Aiwa ADF-770 tape deck
Old 30th August 2008, 02:17 PM   #1
mixter_v is offline mixter_v  United Kingdom
Default Need new drive belts for Aiwa ADF-770 tape deck
my belts have perished on my Aiwa ADF-770 tape deck after having it boxed up for a couple of years.
Anyone know where I can get a replacement set, and fitting manual as it looks like some of the mechanism has to be dismantled to change them.
Any help appreciated.
Old 1st September 2008, 08:41 PM   #2
magentawhale is offline magentawhale  Netherlands
Having recently changed some belts in the transport of my Aiwa XK009 deck, it turned out to be a lot easier than I expected it to be initially. If the transports don't differ too much, there are only a couple of screws that need to removed for acces to the transport. I think I bought the replacement belts from someone on Ebay Germany - I will have a look and see if they offer replacements for your Aiwa as well.
Old 1st September 2008, 08:44 PM   #3
Thank you for your help.
Old 5th September 2008, 09:29 AM   #4
burbeck is offline burbeck  United Kingdom
hi mixter,
most likely you will have to take off the existing belts and measure them, there is usualy at least one that requires dismantling the mechanism.
if you have not do this before can be quite tricky on some models, my advise is take notes and photos of the dissasemly.
the rubber belts can flat type or square section, these replacement types are availible from online supliers in uk here is one that i use http://www.cricklewoodelectronics.co...me.php?cat=269
have fun
regards
bob
Old 5th September 2008, 11:12 AM   #5
Mooly's Avatar
Unbelievable ! I had one of these for years, flogged it to death, I fitted 3 heads, new capstans- the microgroove finish wore shiny causing flutter, motors, pinch rollers springs etc etc. Gave it to a friend about 5 years ago !
Only got rid of all the spare bits recently.
You have to remove the "bracket" with the two endfloat adjusters on them. I always took the whole mech out. 4 screws I seem to remember.
www.cpc.co.uk used to do all the spares but that was ages ago.
Take the belts off, just measure "end to end" with it flat on the table. Double the reading to get the circumference of course.
CPC still do I think a lot of belts listed by size.
Edit -- Think you can just loosen the bracket and wriggle the belts out that way to save removing the mech.
Old 6th September 2008, 03:49 PM   #6
Mooly,
Bit of bad luck on my part, then. Problem I have is the belts perished, so I cannot measure them
So, the only way I can think of solving this is with belts specific for the deck rather than generic by size.
I suppose I could get a range of elastic bands to see which is the best size around the drive, but I am not wholly sure of their routing.
Don't suppose you took any pictures of your mechansim when you have tinkered?
Old 6th September 2008, 06:29 PM   #7
Mooly's Avatar
Sorry no pics but the run of the belts is straightfoward I remember.
Look down on the mech. Going from memory now.Theres an "outer belt" which is last on and first to take off. It runs in line with the motor pulley to the rim of the capstan nearest the middle of the deck (I think) The belt sits on the flat edge, dont worry it won't fall off, a flat belt like these- think they were about 0.8 mm thick and about 4 or 5 mm wide self centers due to the curvature of the motor pulley. The belt linking the two flywheels was slightly narrower e.g. 3 or 4 mm.
Try some thin strips of paper to get an approx size, then get a belt that is slightly too big, then keep cutting and glueing (super glue -tinyest amount ) to get the correct size, then measure and get new.
If they are that perished I fear you may have other problems, the idler tyre on the little pulley on the reel motor and the pinch rollers as well. Check they haven't gone "guey"
Old 7th September 2008, 01:54 AM   #8
hi
wow mooly what a messy lad you are, the fingers are gonna be stuck to the belt, to the pulley, the paper strips and everywhere else.
bloody horrible stuff that super glue.
heres a method that i use, it is fiddly but not messy just takes a little patience. no a lot of patience
remove mechanism compleatly if poss, cant remember if the wiring is plugged in on this model
wrap a piece of sewing cotton around the pulleys as shown in moolys drawing, while holding it tight and square on the belt path. (try it a couple of times you will get it right)
mark a point where they meet (on both ends of cotton)
lay this piece of cotton out in a straight line and measure the distance from one mark to the other. in mm
i use white cotton and fine marker pen for this
this gives the circumference, divide by 3.142 (pie) this gives the diameter.
then buy 2 belts that are one size and two sizes smaller one of these will be perfect. Did i mention width as well.
do same for all belts. then go to the web site i gave you to order them by diameter,
use the leftover/extra belts for flicking ink bombs at the teacher
i do agree with moolys suggestion regarding the other rubber bits check they have not gone gooey
regards
bob
Old 7th September 2008, 03:06 AM   #9
then i remembered this
http://www.donberg.ie/warehs/groupba.htm
regards
bob
Old 7th September 2008, 07:29 AM   #10
Mooly's Avatar
The cottons a good idea. Have you seen the price Donberg are asking. 12.90 and 17.90 euros.
Get a few from somewhere like CPC or, what no one ever seems to do, approach the manufacturer. In the past I have ordered from Aiwa (for the 770) Sony and Pioneer and Denon. No problem and they are often cheaper far cheaper. The only one that ever kicked up a fuss was Teac. Also CPC are spares agents for Aiwa, tell them what parts you want and they probably have them on the data base.
The pinch rollers are easy to change but you have to take the deck out -- which is 2 minutes of a job. I remember now, you could remove the deck and actually screw it to the top frame with a single screw and work on it if needs be. The idler assembly lives behind the cassette door. That's the most tricky thing to work on. The whole door/flap will unclip (circlips) and hinge up out of the way for access.
Me no messy
Need new drive belts for Aiwa ADF-770 tape deckHide this!Advertise here!
Tandberg 3034 tape deck belts gpatoul Analogue Source 3 18th June 2008 09:12 PM
Joining audio-tape turntable belts. Aleksunder Analogue Source 5 28th November 2007 11:14 PM
Replacement drive belts Nam402 Analogue Source 1 11th July 2006 11:17 AM
Aiwa F 660 & 770 Cassette deck Drive Belts bk.bas99 Analogue Source 6 6th May 2006 01:37 AM
TT drive belts. Paul Dimaline Analogue Source 3 17th October 2005 04:50 PM
