Old 26th August 2008, 07:57 PM   #1
AVWERK is offline AVWERK  United States
Default Verion / Cotter stepup trans restrapping info
o represents connecting points
: represents vertical soldered connection
Type S 20+ ohms
o o o o
o o o o
o o o o
o o o o
o o o o
Type PP 20+30 ohms
o o o o
o o o o
o o o o
o o o o
o o o o
I have type P 2-30 ohms also, but the spacing won't correctly translate
David
Old 26th August 2008, 08:14 PM   #2
Type P 2-30 ohms
left to right
Ist row 1 and 3 points
2nd row 2 and 4 points
3rd row 1 and 3 points
4th row 1 2 3 4 points
David
Old 6th September 2008, 01:58 AM   #3
Example:
Here's the P strapping for 2-30 ohm MC's
[IMGP0689.jpg]
regards
David
Old 15th January 2009, 12:21 AM   #4
palewin is offline palewin  United States
Default Any gain info for the different strappings?
The strapping info is very useful. I'm hoping I can restrap my "P" version to lower the gain and increase the loading seen by the cartridge. To be honest, the load impedance ranges, with their overlap, are really not very informative. Does anyone know the step-up ratios and/or gain in db for the PP or S strappings? My understanding is that my "P" version has 24.5 db of gain, or a step-up ratio of 16.8:1. Thanks!
Old 11th January 2010, 03:12 AM   #5
newkid's Avatar
Originally Posted by AVWERK View Post
Example:
[IMGP0689.jpg]
regards
David
the L channel is difference from R channel in this picture
Old 11th January 2010, 03:24 AM   #6
newkid's Avatar
MK2PP is optimized for phono cartridge in the 20 to 30 ohm range,such as the EMT,however,itis is possible to use either the Type P or Sfor cartridges in 20 to 30 ohm,but the transformer will not necessary be optimized for these cartridges, primary DC resistance <12 ohm,voltage ratio 8.88 to 1, gain:19db.
MK2S is for cartridges of 20 ohm or higher,such as denon & satin,for which it supplies the appropiate gainand gives the best low-frequency response,primary DC resistance < 12ohm,voltage ratio 8.88 to 1 gain:19db
Old 11th January 2010, 04:06 AM   #7
newkid's Avatar
the cotter MK2P i have strap info:
o o o o
o o o o
o o o o
o o o o
o o o o
Old 11th January 2010, 04:42 AM   #8
newkid's Avatar
o o o o
o o o o
o o o o
o o o o
o o o o
up schematic does not display correctly,it shoud be :
Old 11th January 2010, 04:51 AM   #9
newkid's Avatar
in the attachment i post:
the L channel should read from top to bottom,the R channel read from bottom to top,these 2 channel strap info looks same in this way.
Page generated in 0.11409 seconds (77.04% PHP - 22.96% MySQL) with 11 queries
