| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#31 |
Sure...
#32 |
I tried the following threads and the results are far better than the ordinary rubber/polymer belts. 1. Surgical silk 2. Nylon 3. Kevlar Best regards, Bins. |
#33 |
The old flat belt from SOTA was getting loose and slippy so I decided to try thread or string drive. Had to turn a new drive drum with a groove for the thread but that was quickly done. Then to try several different "strings". Most all worked well enough but the best I found is what WellTempered uses for the Amadeus TT, .004 transparent nylon thread by Coats thread company. (The spool I have is actually .005"). It took a few tries to get exactly the right length for no slippage but just enough "give" to let the synchronous motor start up reliably. Too tight and the motor won't start, too loose and it has trouble starting and slips. Get it right and it works very well. Besides it is soooo much cheaper and easier to get than the SOTA belt.
Bill |
#34 |
| TT drive belt | woodturner-fran | Analogue Source | 73 | 19th November 2008 10:35 AM |
| CD Tray Belt | isticism | Parts | 6 | 30th September 2008 04:32 PM |
| Belt driven Motor placement and belt properties | luvdunhill | Analogue Source | 2 | 16th July 2008 05:21 PM |
| Connoiseur BD1/BD2 belt | planet10 | Analogue Source | 11 | 18th June 2006 11:40 PM |
| Orion's belt | Mats J | Multi-Way | 14 | 16th February 2004 01:02 AM |
| Page generated in 0.07644 seconds (71.83% PHP - 28.17% MySQL) with 11 queries |
