Best DIY belt - Page 3 - diyAudio
Old 3rd April 2009, 06:01 PM   #21
Hi Tom,
It's great you're showing up here in underground world of homebrewed TT builders.
For DIYers the sheer platter mass is the easiest and sometimes the only practical way to reach a decent speed stability. But here is the catch: unevitatble inaccuracies of "kitchen table manufacturing" may nullify the whole gain. Two things mostly matter here: bearing tolerances and platter balancing. Widely used conventional journal bearing has an inherent drawback: platter shaft goes into precession within the bearing gap. Thick platter with the long spindle suffers from dynamic unbalance, especially when the platted CG is set away from the bearing geometrical center. Piere Lurne discussed this topic in length.
Bearing drag fluctuations due to this phenomenon shall be much more substantional, that stylus drag variations, with all my greatest respect to Chris Brady. So, staticaly/dynamicaly balanced heavy platter with the CG at the center of tightest tolerances bearing is the ticket IMHO. How close a humble DIY builder can approach to this target? - I dunno.
Old 3rd April 2009, 07:04 PM   #22
galibier_man's Avatar
Greetings,
Ah, if I only had the time, this (DIY) section of the internet would be one of my favorite places to hang.
The DIY-er has one great advantage over the manufacturer - the ability to put huge amounts of sweat equity into their projects.
In the areas of both electronics as well as turntables, obviously a solid design counts for a lot, but frequently manufacturers have to make cost compromises in order to achieve a realistic price for products other than their cost no object items.
Where the DIY-er can somewhat easily stomach a boutique transformer or adding 20 more pounds of platter mass, the manufacturer might be cost constrained from doing so. The cost effects of weight seem to be exponential, and sometimes, I wish I was in the cartridge business instead.
So, the DIY-er can make up for minor design deficiencies in this manner - bearing in mind of course that a solid design is still the basis for any success.
With respect to the bearing design, Chris Brady, myself and the other members of the original "Teres-5" took this center of gravity issue very much to heart - with respect to the idea of any precession that might ensue from wobble resulting from too high a center of gravity.
What we learned, is that while this geometry is a good thing to achieve (and we designed it into the platter/bearing), its need can be obviated by holding aerospace tolerances in your bearing clearances.
There's another place where a DIY-er may not be at a disadvantage - bonding with their machinist. If you can find out what your machinist's favorite micro-brew is, you can make quick friends (make sure they're not enjoying it when making your parts)
An interesting thing about many machinists is that they're very passionate about some esoteric pursuits, and will come in on days off to make stuff for them. Frequently, it's guns and hot rods ... at least in my experience.
What this means is that you have a chance at bonding with them indirectly by showing them that you're as out of control as they are. Sick minds think alike, and we all have to stick together
Thom @ Galibier
Old 4th April 2009, 04:38 AM   #23
binspaul's Avatar
Send a message via Skype™ to binspaul
Hi Clack,
I have attached the animated image of the square knot I am talking about. It is also known as reef knot. Will that fit the purpose or do you have a image of the knot you were talking about ?
Bins.
Old 4th April 2009, 06:15 AM   #24
binspaul's Avatar
Hi Clack,
I got an image on how to make a knot (Actually it is for the Scheu turntable). I think, we can also follow that one. Is that the same you follow ?
Bins.
Old 4th April 2009, 08:09 PM   #25
dario54 is offline dario54  Israel
Hello,
For those, like me that cannot use tape for lack of space and must or prefer to use strings, here's the solution as published few years ago by Teres (if I remember well) before they started suggesting tape:
http://www.marinews.com/Double-Blood-Knot-251.php
Hope this helps....
Dario54
Old 5th April 2009, 03:53 AM   #26
binspaul's Avatar
Hi Clack,
This thing is getting bigger and bigger with more options. Which one will you suggest ?
Bins.
Old 14th May 2009, 07:09 AM   #27
binspaul's Avatar
Got a document on how to tie a belt knot (From Well Tampared Labs)
Bins.
Old 14th May 2009, 09:49 AM   #28
Clack is offline Clack  Italy
Hi everybody
I apologize for my long absence but the system didn't alert me for new posts. Funny.
I saw the pics posted by Binspaul and now I know I am using a square knot. Don't know if double blood knot could do, seems too big to me, but if Teres says so, it should work.
Old 15th May 2009, 05:37 AM   #29
binspaul's Avatar
Hi Clack,
Nice to see you back. I am planning to go for the square knot. I will try with the following fibers and will let you know the results:
* Surgical silk (Single strand as well as braided)
* Nylon (Single strand as well as braided)
Best regards,
Bins
Old 15th May 2009, 11:40 AM   #30
Stuey is offline Stuey  Australia
Hi Bins,
Maybe you could try braided fishing line (if you haven't already!) as you can get different stretch characteristics.
Some of the better monofilaments have a nice soft feel, too, and are better to tie.
You may even be able to melt the ends together rather than knotting.
Cheers
Stuey
Connoiseur BD1/BD2 belt planet10 Analogue Source 12 13th November 2012 03:16 PM
TT drive belt woodturner-fran Analogue Source 73 19th November 2008 10:35 AM
CD Tray Belt isticism Parts 6 30th September 2008 04:32 PM
Belt driven Motor placement and belt properties luvdunhill Analogue Source 2 16th July 2008 05:21 PM
Orion's belt Mats J Multi-Way 14 16th February 2004 01:02 AM
Copyright 1999-2017 diyAudio
