Old 17th August 2008, 07:42 PM   #1
Default Turntable platter from plaster
I'm thinking of experimenting with plaster (gypsum) as material for a turntable platter. The platter itself would be casted in a pre-shaped mould, with mesh wire for reinforcement. Since the surface of the casted platter remains vulnerable, I would like to use something to impregnate it with (Pretex, a textile stiffener could be used for this purpose, if I'm informed correctly). Does anyone have any experiences on this matter?
Old 17th August 2008, 07:58 PM   #2
magentawhale
There's a product called Jesmonite which may be of use to you...
http://en.wikipedia.org/wiki/Jesmonite
It "rings" like porcelain when thin but if you are casting a large item that should not be a problem.
It also transfers perfect detail in castings so any imperfections in the mould/mold will be perfectly reproduced in the platter.
John
SWMBO's stuff http://www.wowthankyou.co.uk/names-in-lights
Old 17th August 2008, 08:29 PM   #3
Thanks, this might be just what I'm looking for!
I could probably cast the whole platter from this material, and wouldn't have to bother with impregnating it at a later stage.
Hans
Old 17th August 2008, 08:33 PM   #4
Pure plaster, even with wire, sounds too fragile and chip prone. I had never heard of that Jesmonite stuff, and it sounds really interesting. I've considered similar things using fiberglass filled concrete, Structural Skin by Conproco, but the surface would definitely need an overcoat of something nicer, both for cosmetics and if one wanted to machine it true. The Jesmonite sounds like it could possibly be trued up on a lathe with a carbide tool. Now you've got me thinking about casting a plinth.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 17th August 2008, 08:51 PM   #5
Something I didn't mention in my initial post is that the platter would actually (partially) rest on a subplatter, Rega-style. The platter doesn't become directly attached to the bearing, which I think would be the most vulnerable part. The chipping was something I was more worried about, hence the idea of impregnating it with something more rigid.
Old 17th August 2008, 08:53 PM   #6
The mirror frames and clocks are cast with Jesmonite using a retarder to give you more time to get the bubbles out.....
http://www.artsquirrel.com/Sculpture...sculpture.html
Once fully cured it's very hard, you should be able to true it on a lathe with some experimenting. You would have to plan the mould carefully, strong enough to support the considerable weight and accurate enough that minimal trueing up would be needed.
I would think you would be into a fibreglass mould if you want to pour it in one hit. You could also pour in stages but this may cause weak areas in the "strata". That said, you could have some nice layered colours as it takes pigment or metal powders nicely.
Be warned though it's addictive. There's something delightful about turning a mould out and seeing a new thing, until you spot the bubbles that is!
John
Old 17th August 2008, 10:24 PM   #7
kevinkr's Avatar
What about getting this thing balanced? I can't imagine as cast that it would have uniform enough mass distribution not to need balancing..
I could be wrong..
www.kta-hifi.net
Old 17th August 2008, 10:25 PM   #8
Nanook is offline Nanook  Canada
Nanook's Avatar
Default why not use an agitator?
Basically vibrate the whole mold until th bubbles stop?
stew -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made
Old 18th August 2008, 01:11 PM   #9
Just found out that Celestion made a speaker from the same material....
Old 18th August 2008, 02:51 PM   #10
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
There are 4 types of Jesmonite.......?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Turntable platter for the 2008 Maxon group buy PixelPlay Group Buys 131 8th November 2008 12:11 AM
Project One Turntable Platter Problem SigloOne Analogue Source 4 5th March 2008 02:39 AM
turntable platter impedance matching zeliboba01 Analogue Source 2 23rd August 2006 07:55 PM
FS: New Teres Turntable Platter and Bearing Assembly jdubs Swap Meet 0 23rd October 2004 10:22 PM
Platter mat for TD124 turntable. ashok Analogue Source 3 19th March 2004 03:20 PM
Page generated in 0.10907 seconds (78.46% PHP - 21.54% MySQL) with 10 queries
