Old 12th August 2008, 11:26 AM   #11
Originally posted by mashaffer
No I don't. It was my Dad's and I have no intention of selling so
never looked it up. The tone arm is a rather massive one with no
anti-skate that doesn't work all that well with modern cartridges.
I used it for quite a while as my main table but I now have a modern
table (consumer grade) with a much lighter arm for the LPs.
Some day I may have the money for a second tonearm for the Thorens but that will have to wait.
Well TD124's go for an arm and leg and plinthed along the lines
of a Garrard 401 / 301 they are outstanding performers, to some
the best turntable available. A mono console ? bit of a waste ...
The TD124 does not come with an arm so I've no idea what is fitted.
/sreten.
Old 12th August 2008, 11:50 PM   #12
Pictures of the tonearm are here...
Some Cartridge and tonearm input please
From the help I got there I decided not to use it for LPs but it seems like I ought to be able to fix it up enough to use it for 78s.
It is no doubt far from best use of this turntable but at the moment I don't have the money to put a modern tonearm on it and get another table for 78s. I suppose I could just use the changer in the console for the 78s but that still wouldn't allow me to get an arm for the Thorens. I had thought to build my own arm but I have too many irons in the fire right now.
I suppose I could try to figure out how to put the arm from my current LP table on the Thorens... hmmm... would be another learning experience.
mike - www.keepingsundayspecial.org
Old 17th August 2008, 09:29 PM   #13
kevinkr is online now kevinkr  United States
kevinkr's Avatar
<snip>
IMHO that would far from the worst thing you could do, and it probably would not be too difficult. I'd give it a try pretty close to immediately. Unless you have a very good modern deck it is quite likely that the TD-124 will blow it completely out of the water.
www.kta-hifi.net
Old 17th August 2008, 10:00 PM   #14
Kevin;
Do you have any pointers to information on how to make a properly aligned plinth for it? Maybe I can figure out a way to add a second plinth and use both arms, the old for 78s the new for LPs.
BTW my modern is this one only silver color instead of fake wood.
http://cgi.ebay.com/REALISTIC-LAB-44...QQcmdZViewItem
Old 17th August 2008, 11:16 PM   #15
Actually I take that back. It is exactly like the one on ebay including the wood grain veneer. I had forgotten what it looks like because it is temporarily out of the system.
I had been using it and it was working fine. I came home one night to find that my wife had moved the stereo system!!! Ever since that unauthorized move the arm skips in the lead out grooves. I tried readjusting tracking force and checking that the table was level but nothing helped. Interestingly it never skips on the modulated grooves only the unmodulated ones at the end. And it doesn't matter where the lead out grooves start. Odd.
Anyway I have not gotten around to opening it up so if you have any ideas on what to look for please let me know.
Old 18th August 2008, 10:14 AM   #16
Played with the 440 a bit last night. I opened the bottom and watched as I moved the arm and the tension feels about the same all the way to when the return is triggered and beyond. It appears that it is either optical or magnetic sensor so that is not the problem.
There is however what looks like a small black brake shoe on the shaft which I am guessing is the anti-skate. I will check and see if I can tell anything tonight but it just may be that the mechanism for the anti skate got messed up in the move and is applying max force all the time or something like that. It feels like a fair amount (though not huge) of resistance but I have no other to compare it too as the tonearm on the Thorens had no anti-skate.
Old 18th August 2008, 10:47 AM   #17
dnsey is offline dnsey  United Kingdom
I'd be looking for a better arm for the TD than that.
As your budget's limited, how about this:
Lenco turntables have become very popular in recent years, but most audiophile owners discard the original arms in favour of something more sophsticated. There are threfore a lot of these arms floating around very cheaply, which would be a decent start for your TD. You will probably have to replace the knife-edge bearings, as these are known to fail, but replacements are easily available. You will then have an arm with replacable headshells, so you could have an LP cart in one shell, and a 78 one in another (together with any additional weight required to save changing tracking force).
Just a thought, and the way I'd probably approach things.
As for the plinth, just make as solid and heavy a box structure as you can; you can always upgrade to something more esoteric later. You may well need to replace the Thorens' 'mushroom' suspension grommets, as they will probably have gone flat!
Old 18th August 2008, 09:25 PM   #18
Actually I used the wrong terminology. What I meant was how to properly mount and align the arm on a new (or aux) arm board. With all the other projects on hand I will probably just have to get the 440 performing up to its potential and possibly scare up a 78 cartridge for the Thorens leaving the LP arm for later. To many projects... too little $$$... to little time.
Does anyone know anything about Denon dr-300 cartridge? chengs Analogue Source 3 20th December 2007 05:56 AM
DIY Cartridge? dnsey Analogue Source 22 6th August 2006 05:59 PM
FS: ADC 990EX Cartridge transducer Swap Meet 0 20th December 2005 08:38 PM
a new cartridge.... marcanto Analogue Source 2 29th September 2005 07:24 AM
EMT TSD-15 cartridge tgroendahl Analogue Source 0 8th May 2005 12:52 PM
Page generated in 0.12152 seconds (81.44% PHP - 18.56% MySQL) with 10 queries
