| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#151 |
Hmm, still trying to puzzle this one out:
-I currently have a 60hZ, low-speed machine. -I could install a high-speed motor and capstan, but only 50hZ units are available (if at all). -If I did, I would need to supply JUST the capstan motor with 50hZ voltage. that means, probably, building a quartz synthesizer, as Steerpike suggested. I've not yet encountered one, so I don't know how complex / how large / how expensive they are. Is this insane? I'm beginning to suspect it may be. |
#152 | |
www.kta-hifi.net |
#153 |
Ha! Yeah I think you said it Kevin. I actually have a couple of Otaris that I'm fond of, both are early-model 5050s, a 1/4" 2-track and a 1/2" 8-track. They are generally very solid pieces of equipment. I think I was just reeled in (seriously, no pun intended) by the sexiness of tubes.
Speaking of which, I know that some company (Bottlehead?) makes a tube amp replacement for the Otari, but it's darned expensive. I have built tube amps before, I wonder how hard it would be to fabricate them for the 2-track.... Oh no, better not get started down that path! Many thanks, Seth |
#154 | |
Needle Doctor 1-800-229-0644, Pro-Ject Speed Box SE II or the Linn Valhalla power supply. Not that I imply that one will work with the G36, but the principal is identical. It would run ONLY the capstan motor. $600 is exceptionally expensive for what is inside it, but I suppose they feel they need to justify their time spent designing it. The fabrication cost is one 25W mono chip amp + power supply, plus an additional transformer. The 50Hz reference is then either your computer, an old MP3 player, or a quartz crystal plus sundry ICs (about $10 worth). If you wanted to boldly go where no ReVox tweaker has gone before, you could put an A77 or B77 capstan motor + drive board into a G36. It's a far torquier motor. Everything is possible to those will it!
Steerpike's Toybox |
| Help restoring an old power amp? | audiodane | Parts | 5 | 15th August 2008 09:06 PM |
| amp trouble?? expert opinions please | clenchxxl | Car Audio | 2 | 10th January 2007 07:28 PM |
| restoring old clock | ericpeters | Digital Source | 3 | 29th June 2004 08:58 PM |
| help with restoring amp | skyraider | Tubes / Valves | 10 | 8th May 2004 03:35 AM |
| Page generated in 0.09792 seconds (73.97% PHP - 26.03% MySQL) with 11 queries |
