floppy motor for my rega?
Old 8th July 2008, 02:33 PM   #1
planarboy is offline planarboy  Australia
Send a message via MSN to planarboy
Default floppy motor for my rega?
I'm having a hard time looking for a few facts about floppy drive motors:
Would it be easy to put in my rega plinth?
As in, is it easy to get the motor to do 300rpm, and can a longer spindle be put in for the pulley? Or do y'all attach the pulley some other way.
If I glued the pulley to the motor I would end up with a wobbly paperweight.
Does this motor alternative really stack up against the pricey OL and etc DC motors?
I'd love to not spend $800AU!!
And thus am very interested if the floppy motor ever evolved to the point of rega drop-in.
Old 9th July 2008, 05:27 AM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default planarboy..
look here
and here as well
The first link is the project, the second shows a "surface mount" to the floppy drive setup. If you don't mind either hacking up your existing plinth, or making a new one, the floppy drive could be sunk into the plinth and a cover placed over top. The pulley needs to be machined to accept the shaft diameter of the floppy motor, and could be glued using something like a non hardening rubber cement (easy to remove). Just a couple of ideas.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 12th July 2008, 10:34 AM   #3
AudioOrigami is offline AudioOrigami  United Kingdom
AudioOrigami's Avatar
Send a message via MSN to AudioOrigami floppy motor for my rega?
yea it could be done for a rega i would think...its fun to play with...
i must point out that some floppy motors are easyer to mod than others...
so collect a few and have a look at how small the pcb and motor unit is
some of the laptop and newer floppy motors i have seen are ideal to mod...because they had a seperate pcb from the motor
you can use 3.6v-6v battery or mobile phone charger to power it...so low voltage and very safe to play with
www.audioorigami.co.uk
floppy motor for my rega?Hide this!Advertise here!
Can I use a computer PSU with a floppy/DVD motor drive TT? morepower4me Analogue Source 19 25th March 2009 05:04 AM
Floppy drive motor BluesMagoos Analogue Source 20 13th June 2007 06:56 PM
DC motor for Rega P3, need help please. Vinyl-Addict Analogue Source 4 20th February 2004 01:09 AM
