diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Ultrasimple MM/MC RIAA Preamp mkIII (http://www.diyaudio.com/forums/analogue-source/125745-ultrasimple-mm-mc-riaa-preamp-mkiii.html)
GlidingDutchman 2nd July 2008 01:17 PM
2 Attachment(s)
A friend of mine (Ludo) tweaked the circuit by Mads K.
I a having trouble getting it to work so I thought I post it here for some discussion.
peranders 2nd July 2008 01:23 PM
Have you checked the working points for all three JFET's? Are the JFET's capable of 12 mA Id?
GlidingDutchman 2nd July 2008 01:29 PM
20mA max...
D
Conrad Hoffman 2nd July 2008 02:36 PM
You're at the mercy of whatever current flows with the gates grounded (Idss?, I forget), and this can vary. You might have to adjust the upper three resistors to get the voltage drop you want. Other than that, it looks like it should work fine. I assume the gain is rather low and another gain stage has to follow this.
GlidingDutchman 2nd July 2008 03:08 PM
I guess so...
Conrad - this design stems from here: http://www.diyaudio.com/forums/showt...postid=1550522
and the unit, as designed by Mads K works just fine as it stands with my Kiseiki Purpleheart Sapphire low output MC cartridge...!
D
tschrama 2nd July 2008 07:42 PM
If you really want to optimize the circuit, read the optimum Voltage supply idea of Nelson in:
http://www.diyaudio.com/forums/showt...88#post1552988
and posts before there...
Copyright 1999-2017 diyAudio
