a tuner for <img .64 to rework and case
Old 12th June 2008, 02:27 PM   #1
jaudio is offline jaudio
Default a tuner for $1.64 to rework and case
I found this http://www.circuitcity.com/ssm/Audio...oductDetail.do
(in-store special i $1.64). The tuner section is decent, labeled and easy to add rca plugs. Recased, I think it will make a nice enough tuner. For those,who has the Accurian amps this should be right up your alley
will post pictures later
Old 15th June 2008, 03:05 PM   #2
I started taking the dock apart. this is what I find so far
the dc from the radio section is below .2mv both channels
The output impedance is about 7.5k
Old 15th June 2008, 03:09 PM   #3
cutting the top led(I,only use the bottom),will cut some of the brightness but you will still need to add resistors.
Old 15th June 2008, 03:17 PM   #4
Cutting four wires and adding RCA plugs is all you need to connect the tuner.
BTW the bass boost button causes some weird mono so you won’t be able to use it and keep the output in stereo
Next I will find and change the coupling cap.
Old 15th June 2008, 03:22 PM   #5
picture of inside
a tuner for <img .64 to rework and caseHide this!Advertise here!
SMD Rework Stations Reccomendations? Zero Cool Equipment & Tools 2 23rd March 2008 03:35 PM
Pace soldering/rework station speakerguy79 Parts 4 31st May 2007 05:54 PM
Rework -- cleaning up through-holes jackinnj Everything Else 1 20th March 2007 05:14 PM
Using heat Lamps for DIY IR rework fr0st Parts 0 23rd July 2004 01:43 PM
PACE MBT Rework Station on Ebay damonpip Swap Meet 1 14th December 2003 10:48 PM
Copyright ©1999-2017 diyAudio
