Old 31st May 2008, 08:25 AM   #1
Default Dual CS 5000 Cueing Lever Question
The other day I had to disassemble my Dual CS 5000. After I put it back together, the cueing lever is not lifting the arm. I have taken it off and put it back on ten times and it is not working. I have downloaded the manual but it is no help here. The cueing lever is connected to the the arm rest. It seems pretty simple. There is only one screw involved. The only tricky part is that there is a plastic piece on the under side of the rest by the lever. I have tucked it in and left it out. Neither seems to work. Any help here will be greatly appreciated. I have been lifting the arm by hand for a few days now and I am afraid that I will start scratching my albums.
Old 1st June 2008, 09:04 PM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default look for a small metal pin....
under the plastic cover is a "teeter tooter". A smalll pin goes into the hole below the lever and into the plastic cover. When the solenoid under the cover is actuated, it allows the pin to drop and then you can raise or lower the arm manually.
Or if the solenoid is damaged, it may not allow the pin to drop and therefore the arm to drop.
I'll see if I can get some photos.
stew
stew -"A sane man in an insane world appears insane."
Old 2nd June 2008, 04:08 AM   #3
Thanks for the reply. I will take it back apart and look for the solenoid. If you do have pictures that would be a great help. Thanks again.
Old 2nd June 2008, 04:28 AM   #4
Nanook's Avatar
Default I'll have to dig up the old CS5000 I have here, and take some photos.
But no real problem.
stew
Old 5th June 2008, 03:07 PM   #5
I see that you are a Zappa fan. Next week Zappa plays Zappa will be here in town at the House of Blues, New Orleans. No one wants to go with me. Can you believe that?
Old 9th June 2008, 02:26 AM   #6
Hey, Nanook. I guess when I took the turntable apart I lost the pin that pushes the solenoid. I just made one out of a paper clip and it works perfectly. Thanks for the tip. It saved me.
Old 9th June 2008, 10:13 PM   #7
Nanook's Avatar
Default seinfeld....
I did take some photos, (but I couldn't find the pin either! ). Curious, though. Why did you need to take it apart? Tone arm to circuit board wiring? atypical Dual weakness.) I must say the whole table is really a POS, too much plastic, too much electronics, no protection for the transformer..
But pleasant enough to listen to. With a "new" verdsion of the 504 bing produced, I think most Duals will increase in value.
stew
Old 10th June 2008, 02:39 AM   #8
I had an intermittent left channel patch cord that needed to be repaired. I took the deck apart to unplug the patch cords from the tone arm assembly. This turntable was a freebe from my dad. It looks nice but I wasn't all that impressed when I got it apart. It sounds OK, not wonderful. It will do for now.
Old 10th June 2008, 03:41 AM   #9
Nanook's Avatar
But pleasant enough to listen to. With a "new" version of the 504 bing produced, I think most Duals will increase in value.
stew
slaps = acoustic lever? jbell Subwoofers 3 18th February 2009 10:17 PM
A cueing mechanism to buy/DIY theskintman Analogue Source 1 30th June 2008 12:47 PM
Leader LMV-1815 2 Ch Auto dB Lever Meter Mikewong Analogue Source 0 19th July 2007 06:27 AM
Need help with Dual CS-5000 impressions and experence???? Norris Wilson Analogue Source 2 2nd January 2005 10:25 AM
Manual for Dual CS 5000 Zombie Analogue Source 0 5th September 2003 12:02 PM
Page generated in 0.10196 seconds (78.19% PHP - 21.81% MySQL) with 10 queries
