| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hello, First time here and thought that somebody may be able to help out. Sorry if this is in the wrong section.
I have a very basic knowledge of electronics and want to make a radio which can play all the frequencies which it picks up, All the time. So there is no tuning just all the bandwidth (is that the right term?) playing at once. Can it be done electronic gurus? I was thinking that the easiest way to make this would be to change an existing radio. Would this be a good place to start? http://www.maplin.co.uk/Module.aspx?...20kit&doy=25m5 Thank you, Elliot |
#2 |
Are you wanting only AM (Amplitude Modulated) radio signals? That would probably be _much_ easier than FM, or other types.
If you ARE wanting AM only, then it should be easier to make a wideband receiver than it would be to make a standard-type station-tuned receiver. But you would still probably want to limit the bandwidth to something that makes sense, (and) to possibly eliminate frequency bands containing signals that your detector cannot deal with (FM et al). It would probably help if you could be more specific about the intended purpose of the receiver. |
#3 |
I'm curious as to why you would want that.
![]() /Hugo |
| Need CB Radio PA Amp | silentblackhat | Car Audio | 0 | 8th May 2007 06:56 AM |
| PC Radio | LizardDefence | Everything Else | 10 | 4th June 2005 11:13 PM |
| DIY FM radio | elektroman | Analogue Source | 1 | 23rd January 2004 01:15 PM |
| DIY Radio | pinkmouse | Analogue Source | 19 | 28th March 2003 06:39 PM |
| Mod to an old radio | Petman | Tubes / Valves | 12 | 25th January 2003 06:46 PM |
| Page generated in 0.06861 seconds (68.30% PHP - 31.70% MySQL) with 10 queries |
