| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Does anyone know effective mass of Sansui tonearm, or how to measure mass with digital skale?
Thanks Duka |
#2 |
i found contacting needle docter on the net there knowledge is great i have the same deck and loaded a goldring mm i would not spend more than 120 on it because the arm is of very low quality
#3 |
i forgot to say i found opening the unit and changing some things gave me vast improvments in sound.
i have changed the power cable for a russ andrews yellow power cable. the main interconnect was changed for a high performance shielded desighn with shark connecters a very snug fit and gold. the earth was the clinger i pretty much earthed what ever could be and did ths with a pure copper cable. which runs to a crimped spade for termination. with a standard normal cartridge through a sansui phono amp on mm it was silent and i mean silent ! also the sounstage was massive. so when i had put on a better cartridge and a dedictaed slip mat that was from ringmat a reference desighn let me just say this sansui on its own was very serious. not as tight in the bass but deep and traveling. very silent background almost cd like and the top end was smooth. this is a non reference ambient material imagine with maybe 180g vinyl?? |
#4 |
praer4life: Please allow the "shift" key to enter your life - most visitors to this forum do not speak or write English as their first language and are taught proper grammatical English. Think of your reader and make their job as easy as possible.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| An Excel spreadsheet for DIY Tonearm's Effective Mass Calculation. | Padel | Analogue Source | 16 | 7th April 2011 07:48 AM |
| Effective Mass of a SL1210 tonearm | Netlist | Analogue Source | 3 | 4th May 2008 09:26 AM |
| mass loading | aznboi3644 | Subwoofers | 1 | 13th March 2008 11:47 PM |
| Linear tracking tonearm vs. Pivoting tonearm | Don Nebel | Analogue Source | 1 | 4th November 2007 10:49 PM |
| BIC 960 tonearm eff.mass | percy | Analogue Source | 8 | 8th August 2006 10:12 PM |
| Page generated in 0.06706 seconds (76.48% PHP - 23.52% MySQL) with 10 queries |
