Old 30th April 2008, 12:59 AM   #1
pureh2o is offline pureh2o  United States
Default Sansui TU-717 question
Hi all. Can someone tell me if the dial lamps are in a type of circuit that when one burns out, it increases the voltage to the remaining three bulbs, and so forth. Thank you. John.
Pureh2o
Old 20th March 2010, 11:37 AM   #2
I have a TU-717 and the dial lamps are all wired in parallel, off of an 8V secondary winding of the transformer. Mine were burnt out so I just replaced them with white light LEDs.
Rob
Old 20th March 2010, 03:57 PM   #3
Rob
How you do it? with one diode it is around 6vdc ?
Praudio
Old 20th March 2010, 09:58 PM   #4
I used a white light LED from Radio Shack with 220ohm in series. The LED conducts during one half-cycle of the 60Hz voltage.
I did this for all 4 lamps.
Rob
sansui R70 maxpou Solid State 2 1st November 2009 10:21 PM
need help with sansui AU 220 qrius4ever Solid State 2 18th July 2009 05:14 PM
Sansui xr q9 nik75 Digital Source 0 14th June 2009 10:12 PM
noob question about B-1000 sansui ed2000145 Solid State 1 15th May 2009 10:46 PM
Sansui Xr-q7 sakis Analog Line Level 0 4th March 2008 09:39 PM
Page generated in 0.07021 seconds (71.30% PHP - 28.70% MySQL) with 10 queries
