Solid state phono preamp design philosophy - Page 10 - diyAudio
Old 24th May 2008, 09:24 PM   #91
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by PMA
The problem of NS is that they do not show spectrum analysis. THD+N for low levels is always dominated by noise, and is say nothing.
Indeed, when they look like that it's all noise but is it interesting really to know the harmonics when they are so extremely small?
I was pretty disappointed with 49710.
In what way?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 24th May 2008, 09:34 PM   #92
PMA is offline PMA  Europe
PMA's Avatar
I was testing many many opamps in a test circuit with low equivalent impedances (10R) in -IN and +IN, but noise gain 80dB. These NS circuits were very sensitive to interference products - TV row frequency and FM pilot frequency (demodulation, detection in input stage?). Also to USB packets frequency interference.
Old 24th May 2008, 09:43 PM   #93
Onvinyl's Avatar
Well, regarding noise, the corresponding plot of the 49710 is way better. Maybe the 49713 guys had a noisier day...
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 24th May 2008, 09:52 PM   #94
peranders's Avatar
Pavel, was this a really suitable test? I mean you could tell differences but how about in a real circuit?
Old 24th May 2008, 09:58 PM   #95
PMA's Avatar
Who knows? I like the circuits that are not influenced that much by interferences, and I do not think much about THD wars at 0.00001% level. I tend to agree with Charles Hansen.
Old 24th May 2008, 10:42 PM   #96
Onvinyl's Avatar
talking 'bout a functional sample...
Rüdiger
Old 25th May 2008, 12:43 AM   #97
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Solid state phono preamp design philosophy
Gentlemen,
I would like to open a discussion on this topic.
MC phono preamp, solid-state.
Originally posted by ACD
This will be interesting
I suggest we choose to go for an opamp version,
then it must be active equalization with BTJ buffered balanced output.
Hello.
There are some nice low-noise ideas in an old National Application Note:
National AN-222 ( 1979 )
It is ways to use low noise monolithic dual transistors for lowest noise.
Today we have even better such duals. Both JFET and BJT.
I do not know if attached idea captured from AN-222 as a standalone would be for MC.
But for MM cartridge I think it will perform very well.
I am sure people with MM based pickups will read this topic with interest, too.
So I post a couple of posts.
Lineup
Some Low noise Designs web stuff, PDF:
AN-222 Super Matched Transistor Pair Sets New Standards for Drift and Noise
National Amplifier Application Notes - downloads
lineup
Old 25th May 2008, 12:49 AM   #98
lineup's Avatar
Here is another 'old idea'.
It is a capture of a most low noise and interesting circuit.
All discrete with matched monolithic JFET parallelled as input.
Capture from this Paper by Janasek:
Hompage: www.janascard.cz
Design of ultra low noise amplifiers - Vojtěch Janásek
Lineup
lineup
Old 25th May 2008, 02:04 AM   #99
maney is offline maney  United States
Send a message via AIM to maney Send a message via MSN to maney Send a message via Yahoo to maney
Originally posted by scott wurcer
Thank's for finding that A lot of people attribute the input stage on that last circuit to an 80's AES paper. I had been searching through our Analog Dialog archives and missed it.
It's funny the way these things work - I had had that sitting in the PDF reader for, at a guess, maybe a week. I'd come across it in some other thread, presumably something here in the SolidState division, but possibly not - I'd been wandering pretty widely, following the occasional crosslink into some other thread with crosslinks into yet another...
I don't think I'd bookmarked it (d'oh) and had to beg Google for a lead. Luckily I had the title and some authors' names that were less common than Smith or Jones...
Old 25th May 2008, 03:25 AM   #100
Originally posted by Bonsai
BTW, John Atkinson did a review of a phono stage about a year back that used the passive approach (solid state I have to say) and remarked that it had a great sound, but overload capability was only 6dB.
This was a very misleading measurement.
I recall the review in question. Basically, the circuit had a lot of gain and the supply rails were something relatively low, like +/- 8 volts or so. This means a maximum output level of ~5 Vrms, and the large amount of gain combined with a high input signal level so that the unit was near to clipping to begin with. It didn't take much extra input ("headroom") to clip the output of the unit.
Now, 5 Vrms is plenty of output to drive a line stage, so I don't think that's an issue. Basically, JA should have either lowered the gain on the unit (I believe it was adjustable) or else used a lower input signal level.
The entire "headroom" issue is much more complex. In the old days (pre-MC), all MM cartridges put out about 5 mV and all phono stages had a standard gain of 34 dB.
The thing to watch out for is *input* overload, as that can be a problem. But the way these tests are done these days often only shows output overload (clipping), which doesn't really illuminate anything.
Diy Solid State Preamp Pocoyo Solid State 21 17th July 2007 04:53 AM
Solid state preamp gchrist Solid State 4 7th April 2004 11:19 AM
Copyright ©1999-2017 diyAudio
