Solid state phono preamp design philosophy Solid state phono preamp design philosophy - Page 36 - diyAudio
Old 4th January 2012, 09:10 PM   #351
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
I would be interested in one...
Arne K
Don't believe everything you think...
Old 4th January 2012, 09:13 PM   #352
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
PMA:
impressive curves. i guess i'm one of the few folks that admits to still using a mm cartridge.
btw, you must have a fairly substantial stash of the 2SK413/2SJ118 devices.
mlloyd1
Old 4th January 2012, 09:18 PM   #353
PMA is offline PMA  Europe
PMA's Avatar
In fact I will have to seek replacement parts soon, I have several tips that are still available.
Old 8th February 2012, 01:54 PM   #354
hags is offline hags  United States
Pavel, do you have an update on this project?
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 9th February 2012, 05:58 AM   #355
PMA's Avatar
Joe,
several units were produced and they are working and sounding well. But, for the reason of my very extended activities in the field of industrial automation I have to restrict my audio activities for the period of 1 year at least. So, no PCBs or modules for this project would be available now.
Best regards,
Pavel
Old 15th July 2012, 03:19 PM   #356
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Hello solid state! Just wanted to save this thread.
Old 15th July 2012, 05:06 PM   #357
PMA's Avatar
Okay, I will
Old 20th July 2012, 10:02 PM   #358
mlloyd1's Avatar
almost a week and no comments ...
amazing!
mlloyd1
Old 23rd July 2012, 12:36 PM   #359
padamiecki is offline padamiecki  Poland
amazing!
mlloyd1
the people are soldering
regards, Pawel
Old 9th August 2012, 09:48 AM   #360
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by PMA View Post
Gentlemen,
I would like to open a discussion on this topic. MC phono preamp, solid-state.
- active/passive equalization
- discrete/opamp
- BJT/JFET, which position
- power supply, active PSU filter
- enclosure, shielding properties
- wiring, grounding
- SE/balanced
also of interest for the associated line head amplifier (Pre-Pre) of low output/low impedance moving coil cartridges is follow:
Which topology is the best?
Common base (low input impedance) or common emmiter/common source (high input impedance) ?
I prefer clearly the first mentioned (tested e. g. by Audio Technica ART1 (Art ONE), Ortofon Rohmann, several Lyras and AT-OC9 (all MK-versions).
In this case I start follow thread:
Commercial Pre-Pre Amps for Moving Coil Cartridges (MC Head Amps) in Common Base
Solid state phono preamp design philosophyHide this!Advertise here!
Diy Solid State Preamp Pocoyo Solid State 21 17th July 2007 03:53 AM
Solid state preamp gchrist Solid State 4 7th April 2004 10:19 AM
Copyright ©1999-2017 diyAudio
