Solid state phono preamp design philosophy
Old 26th May 2008, 06:01 AM   #131
PMA is offline PMA  Europe
PMA's Avatar
Absolute maximum Id is only 1mA.
Old 26th May 2008, 06:31 AM   #132
john curl is offline john curl  United States
john curl's Avatar
Have you finished college yet? Serious question.
"Condemnation without Examination is Prejudice"
Old 26th May 2008, 06:31 AM   #133
CBS240 is offline CBS240  United States
CBS240's Avatar
I don't quite understand why that is such a problem, it is not a power amplifier. It does have a relatively small transconductance but wouldn't linearity be of concern? I am thinking in terms of a source follower driving a bjt follower, as a buffer.
All the trouble I've ever been in started out as fun......
Old 26th May 2008, 07:02 AM   #134
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Mr. Curl,
sonic degradation in paralleled (even if matched) devices occurs due to the effects of differences in signal processing. Another significant deteriorating factor is multiplied capacitances.
Old 26th May 2008, 07:05 AM   #135
PMA's Avatar
Rt 50 ohm is quite typical load for MC. Often Ct 10n in parallel is added. Would there be any issue with JFET input capacitance??
Old 26th May 2008, 08:23 AM   #136
john curl's Avatar
I have been producing world class pre-preamps for the last 35 years. Most here are rank amateurs, without experience, understanding, or even having done the computations necessary to determine what they are stating. I just can't cope with this disparity in understanding and experience. It is pointless. Also, 50 ohms is usually too low, 100-200 ohms is usually better with modern cartridges. Capacitance is optional and should point out the silliness of worrying about the intrinsic capacitance of the input devices.
Old 26th May 2008, 08:36 AM   #137
PMA's Avatar
Just for the record, 100 ohm with such high as 10nF in parallel makes F(-3dB) = 159kHz.
Old 26th May 2008, 08:44 AM   #138
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Originally posted by Charles Hansen
But to me, this is so elementary that it's not worth wasting much time on. If your circuit has trouble driving the EQ network, then you shouldn't be designing circuits. There are much more subtle points to work on and achieve real improvements than to waste time on these types of basic problems that have been understood for decades.
So, which of the designs testet by audiophile didn't reflect the 'basic problems that have been understood for decades'?
thanks,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 26th May 2008, 08:50 AM   #139
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by PMA
to cover and switch
Is that a problemo ?
Moving coil stage on the left side of the picture. (RIAA is not on it)
The various combinations are PIC stored and push button selected, same-same for the MM stage on the right.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 26th May 2008, 09:03 AM   #140
PMA's Avatar
I do not understand why you speak about problem. All I meant is I just made a proto to verify circuit function.
Solid state phono preamp design philosophyHide this!Advertise here!
Diy Solid State Preamp Pocoyo Solid State 21 17th July 2007 03:53 AM
Solid state preamp gchrist Solid State 4 7th April 2004 10:19 AM
