Solid state phono preamp design philosophy
Old 26th May 2008, 04:38 AM   #121
PMA is offline PMA  Europe
PMA's Avatar
Interesting, Janasek was my competitor in solution of isolation amplifiers for power transients monitoring systems, some 11 years ago. Noise was not important, but immunity against fast CMV voltages was VERY important.
Old 26th May 2008, 04:50 AM   #122
john curl is offline john curl  United States
john curl's Avatar
PMA, the examples were very primitive, nevertheless, at least 40 years behind. I hate to remind everyone, but we in the USA went to the moon in '69, and we had lots of heavy engineering behind it, some of which spilled out into the audio sector. When I look at such examples, it only reminds me as to how far ahead hi end design generally is over what people even know exists.
"Condemnation without Examination is Prejudice"
Old 26th May 2008, 05:18 AM   #123
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
regarding MC, not just noise is a problem, the extremely small amount of energy involved as well. Just a very few devices have the ability to handle so weak signals satisfactorily, others cause (considerably) more losses and distortion. Parallelling does not help, means sonic degradation. However, such annoyances usually don`t make simulation data less fabulous.
For the orthodox minded only battery supply is acceptable.
Old 26th May 2008, 05:56 AM   #124
john curl's Avatar
This is not helpful.
Old 26th May 2008, 06:09 AM   #125
Banned
Mr. Curl,
did you mean my post, Sir?
Old 26th May 2008, 06:12 AM   #126
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
Just out of curiosity, would the KSK595H transistor work well as a phono input stage? I think there is a TO-92 version also. Good linearity with high input impeadance.
All the trouble I've ever been in started out as fun......
Old 26th May 2008, 06:23 AM   #127
john curl's Avatar
Yes, paralleling of parts does not lose information, and is often necessary for lowest noise. Power transfer is NOT the same as signal transfer. We have known how to do this since 1966, due to a paper in the IEE's 'Electronic Letters' found in research labs and in technical libraries at the time, and even today.
Old 26th May 2008, 06:26 AM   #128
john curl's Avatar
ksh device is OK for microphones, lousy for phono in general.
Old 26th May 2008, 06:44 AM   #129
PMA's Avatar
I just opened the paper - you are right, of course. The designs were mainly for cheap PC based measuring cards, I know the story.
Old 26th May 2008, 06:56 AM   #130
CBS240's Avatar
It does state "capacitor microphone applications" in the data sheet. I assume it is has to do with the phono pickup being inductive? Or is this another point of insight chalked up to "experience"?
Solid state phono preamp design philosophyHide this!Advertise here!
Diy Solid State Preamp Pocoyo Solid State 21 17th July 2007 04:53 AM
Solid state preamp gchrist Solid State 4 7th April 2004 11:19 AM
Copyright ©1999-2017 diyAudio
