| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
i used michell orbe inverted bearing, the sub chasis is aluminium , motor and tonearm base bronze and stand alone. platter and ac motor from my michell syncro tt. all bases spiked.
i am waiting acrylic platter 6cm thickness. maybe i could be find magnet ring, i think bronze-teflon platter(30kg). i don't know calculate magnet push. my michell syncro ac motor is have problem. 33.3 rpm no problem but i change 45 rpm from pulley starting problem. problem is not starting i think adjustable speed motor( maybe origin live advanced motor). after all this turntable good sound than my old michell gyro se mk2. deep imaging and good detail.
#2 |
#3 |
#4 |
That's some serious looking turntable Yildiray. I can't help you with the magnet thing, but there are others here who know about this sort of thing.
Good luck, Si. |
#5 |
Great looking turntable, how about some detail on the rest of your system as well, it looks quite interesting..
www.kta-hifi.net |
#6 |
thank you maybe some body help me
because this is the critical think for me. |
#7 |
hi Kevin, thanks.
my system: speakers : reference3a mm decapo-i amp: audionote quest 300b set with tungsol vt231, fullmusic 300b tubes pre amp: diy( dact ct2 , elma switch, a lot of wbt nextgen female rca, audio consulting silver wire and aluminyum case shielding copper). cd player : quad cd-p 99 phono pre: roksan caspian reference speaker cables: tmc gold interconnects: audio note an-vx and diy silver cables with eichmann male rca all stands diy power cables: furutechs and isotek tonearms: rega rb300 with michell tecnoweight and rewireing cardas tonearm cables. sme 3009 s2 improved |
#8 |
Hi Yildiray,
Sounds like have a nice system there, I unfortunately do not know the answer to your question, but I imagine someone here who does will have some ideas for you within the next few days.. (weekends can be a bit slow here.) Which of your arms do you prefer? I have an SME 3009 Series II which I like quite a lot, and I have rebuilt and modded using some of the Analogtubeaudio.de bits and pieces.
www.kta-hifi.net |
#9 |
I might know (or think that I do) the answer to your question but I'm not really sure what you are asking? If you use the 'search' function you will find quite a bit of information with regard to magnetic bearings. The reason you motor is reluctant to start the deck at 45rpm is likely 1/ motor torque is too low - look to the electronics as I believe the Syncro uses a high torque AC motor. 2/ the belt tension is too low - try moving the motor pod a little further away - the belt is stretched quite tight on Michell turntables, in my experience. I suspect that it is 2 and you are experiencing belt slip.
Changing the motor to one that allows electronic speed adjustment will not cure your slow start-up issue as it is a torque related issue - it is likely that DC motor you change to will have less torque than the unit you now use. |
#10 |
Hi Yildiray
If I understand right your platter weight is 30kg. If that is the case your turntable motor seems to be doing ok to me. Push starting at 33 rpm will not do any harm and seems ok unless you do not want to push start. Once rotating you will not need a powerful motor as the weight of the turntable will keep the speed constant. If you do not want to push start I would fit a second turntable motor. Don |
| Lightweight turntable project | JesseG | Analogue Source | 25 | 18th March 2009 05:46 PM |
| How to model box w/incomplete parameters? | critofur | Multi-Way | 5 | 5th May 2008 12:00 AM |
| Hafler DH500 ebay incomplete, parts | Mattyo5 | Swap Meet | 0 | 16th February 2008 01:35 PM |
| Another DIY turntable project | Phileas Fogg | Analogue Source | 3 | 17th December 2006 05:05 AM |
| New project: turntable! | matthias | Analogue Source | 3 | 12th May 2004 04:24 PM |
| Page generated in 0.12085 seconds (83.70% PHP - 16.30% MySQL) with 10 queries |
