How to mount a cartridge properly?? - diyAudio
Old 27th April 2008, 05:00 AM   #1
IamKai is offline IamKai  United States
Default How to mount a cartridge properly??
Since I graduated from P mount, (7 carts since then) the shops have always mounted the things for me.
This time, I wanted to do it myself.
I took the little paper template like I read to do and set it up.
It sounds really good till you get past halfway on the record. Then it starts to mess up the S's and T's badly.
Is there a trick to getting the thing aligned the right way in the middle?
(I was told by a friend that he got rid of his protractor and prefers the tagency template paper.)
Any of you know the trick?
Old 27th April 2008, 11:53 AM   #2
AMV8 is offline AMV8  United Kingdom
Hi
I recomend putting a clear plastic disc on the turntable ( you can buy them ) and setting up your cartridge in the centre of where the tracks will be . Then turn on the turntable and see if the cartride stays still or moves to the inside or outside. This is the only way to set the bias.
The other things to set are;
1) make sure the arm is horizontal
2) make sure the cartridge is set at the right angle vertically and horizontally. You seem to think that the horizontal angle is wrong. If so I think you should be able to see that without using any guages if you set the arm and cartridge innthe centre of the record and look at the alignment by eye. I find that you can set the vertical and horizontal angles fairly well by eye and often better than with a guage.
3) bias
4) playing weight
5) arm bearing pressure and condition
My guess would be that the bias needs resetting. This is best done with a blank disc.
Hope this helps
Don
Old 27th April 2008, 01:12 PM   #3
reins is offline reins  Germany
this one worked fine for me:
http://www.theanalogdept.com/bk_protractor.htm
reins
Old 28th April 2008, 12:28 AM   #4
Thanks for the replies.
I think it is the antiskate weight adjustment.
No matter how low I set it, the tonearm still pulls to the right.
Old 28th April 2008, 02:20 PM   #5
Have you set tracking force correctly? This can happen if the tracking force is too low.
Also, what turntable/arm are you using?
Old 28th April 2008, 03:14 PM   #6
Yes, the tracking force is set right, but I never remember the tonearm having a favor of pulling to the right.
If you use the arm lifter and give it a tap to the left, it stops right away.
But if you tap it to the right, it will travel for a good distance before stopping.
Is this normal?
How to use a multimeter properly. HeavyD'sCustom Car Audio 6 8th May 2009 05:22 PM
Is my WT3 working properly? pp173 Multi-Way 6 22nd July 2008 02:39 PM
how to ground properly? Denis.BR Chip Amps 4 27th March 2007 07:17 PM
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS Swap Meet 1 22nd December 2006 06:18 AM
Art of Properly Grounding jawbreak Chip Amps 4 27th November 2004 07:39 PM
Copyright 1999-2017 diyAudio
