Old 24th April 2008, 08:23 PM   #1
leadbelly's Avatar
Default Balanced input stage beneficial for unbalanced turntables?
I often see the recommendation to switch stock unbalanced turntable wiring to balanced. I understand how this, coupled with a preamp with good CMRR, would minimize hum.
However, in most the few turntables I have taken apart, even though the wiring is unbalanced, there is no path to ground, i.e. both wires float.
So, if you build your balanced phono input stage to terminate this unbalanced connection properly, won't you reduce hum (compared to a unbalanced input stage) since at least some of the noise in the TT wiring will be common mode? I understand that you won't get the full benefit of balanced wiring.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 24th April 2008, 09:07 PM   #2
SY's Avatar
There is absolutely an advantage to making that preamp input balanced if you can rewire the turntable cables.
In my setup, the cables are a pair of twisted pairs inside a single shield. The shield can be connected at either or both the turntable ground end and the phono preamp chassis. The preamp input is a DIN plug with all signal leads floating and connected to the primary of an input transformer. Despite the VERY low output of the cartridge, the setup seems to be quite insensitive to hum pickup.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 26th April 2008, 02:52 AM   #3
KBK is offline KBK  Canada
Just the subject I was getting onto, SY! Excellent timing.
Any DIY 'balanced phono stage' ideas here on the board?
PS. I don't eat packet soup.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 26th April 2008, 04:06 AM   #4
Steve Eddy's Avatar
Default Re: Balanced input stage beneficial for unbalanced turntables?
Except that the wiring isn't unbalanced.
se
Old 26th April 2008, 05:15 AM   #5
leadbelly's Avatar
Default Re: Re: Balanced input stage beneficial for unbalanced turntables?
se
This comment is too subtle for my understanding. Do you mean to say that if you terminate a pair of floating wires in a balanced fashion (i.e. both with a termination resistor to ground) that this is now balanced wiring?
Old 26th April 2008, 05:42 AM   #6
Steve Eddy's Avatar
Default Re: Re: Re: Balanced input stage beneficial for unbalanced turntables?
Basically what I'm saying is that the wiring itself doesn't know balanced or unbalanced from a hole in the ground.
For example, a simple twisted pair of wires is a simple twisted pair of wires whether they're used to connect unbalanced interfaces or balanced interfaces.
se
Old 26th April 2008, 06:48 AM   #7
Default Re: Re: Re: Re: Balanced input stage beneficial for unbalanced turntables?
Gotta disagree with you on this one.
Having built and sold hundreds (if not thousands) of balanced phono stages, we have found that it is critical that the wires do not introduce any imbalance into the system.
The balanced circuit can only reject hum if it is common to both signals.
Most turntables only have a pair of coaxial cables, one for each channel. If you run this into a balanced input, you are going to get hum out the wazoo because the shielded conductor (no longer connected to ground, but instead to either the inverting or the non-inverting input) is going to pick up far more hum than the center conductor of the same cable.
The hum is no longer common mode and cannot be rejected.
If you want to use a balanced setup for your phono stage, you need to have balanced (ie, symmetrical) wires in place.
Yep, a simple twisted pair would be a good example of balanced (symmetrical) cables that would work well with a balanced phono stage.
I would recommend shielding the twisted pair (or twisted quad if both channels are in the same cable) just in case the CMRR of the phono stage is less-than-perfect, but I've seen it work without shielding also.
Old 26th April 2008, 07:04 AM   #8
With what I'm doing these days with cables....shielding is the worst kind of signal damage I have ever come across. For most other folk, carry on - shielding is likely a good idea.
Old 26th April 2008, 07:36 AM   #9
Steve Eddy's Avatar
Default Re: Re: Re: Re: Re: Balanced input stage beneficial for unbalanced turntables?
Okie doke.
Agreed.
Ditto.
Yeah? Mmmm. You talking about cheap turntables that use the same cheap spaghetti wires for the cable that are given away with most other mass market stuff?
Most decent turntables that I'm aware of use twisted pairs or quads from the cartridge to either a DIN plug or RCAs for the outputs.
Far as I'm aware, a coaxial geometry is, as with a twisted pair, self-shielding by way of cancellation.
I think the problem isn't so much that the outer conductor picks up more hum, but rather that in a typical coax, the resistance of the center conductor isn't the same as the resistance as the outer conductor.
Bill Whitlock has demonstrated that in twisted pair cables, just the difference in wire resistance due to manufacturing tolerances is sufficient enough to significantly degrade common-mode rejection in electronically balanced inputs due to source impedance imbalances
Yes. But, in my opinion, because the conductor resistances are the same.
Well, I wouldn't recommend coaxial cables in a balanced system either, but for the reason I gave above.
se
Old 26th April 2008, 07:39 AM   #10
Steve Eddy's Avatar
Hehehe. Not a terribly big fan of shielded cables myself.
I built some unshielded phono cables for a friend of mine and even with a low output moving coil into a 60dB phono stage and 104dB speakers, there was no sign of hum.
se
Unbalanced to balanced input conversion? SQLGuy Solid State 53 19th October 2009 02:39 AM
ESP 101 with balanced/unbalanced input Cloth Ears Solid State 2 17th June 2006 12:12 PM
converting and unbalanced in into a balanced input joyfulstudios Parts 2 12th June 2005 01:41 AM
Balanced line stage, quistion's + unbalanced lykkedk Pass Labs 4 20th December 2002 12:58 AM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Page generated in 0.15673 seconds (84.24% PHP - 15.76% MySQL) with 10 queries
