Old 4th October 2009, 07:24 PM   #251
Steerpike's Avatar
This PCB layout is going slower that I imagined; but it IS going.
Steerpike's Toybox
Old 6th October 2009, 12:12 AM   #252
Steerpike's Avatar
Its coming along nicely: slowly, but nicely.
A few important criteria for my layout, with a view to keeping it aimed at DIY and lowest possible cost:
single sided board; wide tracks and minimal tracks-between-IC-pads for easy etching, wide component spacing to allow substitute components of varying size, no surace-mount components.
This is a protoype board, so it contains component positions for all possible theoretical circuit arrangements. For instance, the op-amps can be configured as inverting, or non-inverting, by adding specific resistors and omitting others; filters can be 1st order, or 2nd order, depending on resistors & caps added, and so on.
If the board works OK, I will NOT redo the major layout to minimise size, or hole-count / component-position-count. Minor fixups, yes, but the board will remain like this so future experimentation and modifications can be tried.
Steerpike's Toybox
Old 6th October 2009, 12:55 AM   #253
Brett's Avatar
This all sounds excellent to me. My plan was always to mount it external to the motor unit and a have a spare 19" rack case for it somewhere.
I will be speaking to someone next w/e regarding some CNC cutting of ply to make the plinth for mine, as well as for my 401, similar to Albert Porter's plinth.
Old 7th October 2009, 04:00 PM   #254
Steerpike's Avatar
I've added a page 6 to document the mechanical / physical prototyping - as distinct from the theory.
Steerpike's Toybox
Old 9th October 2009, 08:03 AM   #255
rich121 is offline rich121  United States
Been "away" for awhile... my home is "gutted" doing a complete remodel..replacing wiring, plumbing, sheetrock, flooring..and even changing room layouts.
Things are really looking good and looks like Steerpike has been quite busy...which is very very much appreciated!
Again, thanks for the effort! I will keep watching as this progresses...
Great Job!!!
Rick
Old 10th October 2009, 02:08 AM   #256
Steerpike's Avatar
I took a break from the controller and did the copper layout for the power supply board here: psu pcb.
This is 8.1" x 3.9" to fit exactly into the box I showed a few posts back. No doubt your favourite component supplier will have all manner of instrument housings in all kinds of styles, if you choose to use the board layout exatly as I have shown it. (it may have a few mistakes in it still, so don't copy & etch it just yet!)
The five TO-220-package regulators are all in a row - these are to be bolted onto an L-shaped aluminium flange to act as a heatsink.
Note that this power supply is NOT a drop-in replacement for the original SP10 with its factory electronics. It doesn't have the appropriate grounding system - although it could be modified to be compatible with the original.
Steerpike's Toybox
Old 12th October 2009, 03:40 AM   #257
ckniker is offline ckniker  United States
Default Nice layout!
That's a very clean layout! If you don't mind me asking, what layout software are you using ?
I've been playing around with a couple of the free-bies (Eagle and 4pcb) and have had to do a huge amount of hand routing due to the difficulties of doing single layer boards with those tools.
Old 12th October 2009, 01:21 PM   #258
Steerpike's Avatar
Tango PCB. By software fashion trends, it's ancient. But nothing newer (in the affordable categories) has impressed me at all.
I'll modify that board a little (a mark 2 version) that doesn't include the transformer on the PC-board, for people who want to use a more generic transformer and housing. Basically, that would amount to chopping off the left-hand half of the board.
Steerpike's Toybox
Old 12th October 2009, 05:55 PM   #259
Steerpike's Avatar
Like a prophecy coming true....CLICK!
Steerpike's Toybox
Old 14th October 2009, 02:40 AM   #260
Hi
I just wanted to say that I will definitely be interested in whatever you produce - pcb, kit, whatever.
I have a motor with no controller, so this will be perfect for me
Really enjoying following this thread :-)
Technics SP10 haydn Analogue Source 10 27th October 2011 03:18 PM
Technics SP10 MKII/SH-10E Voltage Conversion? neiljadman Analogue Source 1 26th October 2009 09:45 AM
WTB: DC motor and controller g-horn Swap Meet 1 14th March 2008 05:14 AM
Servo motor controller? keantoken Everything Else 0 9th December 2006 08:49 AM
TEchnics SP10 MK II Turntable diyman Analogue Source 15 17th December 2001 03:28 PM
Page generated in 0.12700 seconds (81.99% PHP - 18.01% MySQL) with 11 queries
