| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#241 |
It also just occurred to me that the platter does not need to stop dead, but could spin down to an assisted stop. I wonder, though, if a set of coils could be energised so that the platter is held in position when it stops...?
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#242 | |
Location: Scottish Borders - Kelso; on the famous Tweed River!
I am getting older, but am fortunate to have very steady hands and also exceptionally fast reflexes - by any standard. For me I find that the platter when freewheeling can be stopped smoothly and safely with the finger tips (naturally only once the arm has been parked.). I can't see any reason for a brake of any type. I am now using an old cleaned up Lenco in a slate plinth with a Zeta arm.....IF you want a budget set-up this is the way to go. Very cool TT. Despite this performing way above any reasonable hopes, I have a slate block ready for final machining for Kenata usage for my SP 10. I am looking forward very much to the new PS becoming available!! Looking back over the last page or two, I see that I promised to post pics of my off-board PS in the rackmount chassis which comes with the SP10-P. I'll try and get this on the forum this week!!! |
#243 |
I've been re-doing the PCB layout according to the 'size' contraints of the real chassis, & hopefully will have a finished piece of artwork by early next week.
"Electronic braking" I like, it's sort of sexy, and I like a stationary platter when I get to it to turn the record over. Keeping the armature partially energized with a static field would 'hold' the platter and prevent it from turning; what would one need this sort of feature for? It does make the drive electronics more complex, and I hadn't really planned on doing that. There are two possible schemes of "electronic braking": (i) setting the drive amplifier's output to zero volts (not just switching off the amplifiers) is similar to putting a short circuit across the motor and will damp freewheeling rotation quite fast. This is an easy experiment - just short circuit all 3 windings (blue, yellow, red and green wires on the motor) together and try to turn the rotor. (ii) appling reverse torque momentarily will stop the platter *instantly*, but needs careful predictive control to prevent reverse rotation. At very low speeds, the tacho signal ceases to exist, so there is no easy way to monitor speed right down to stand-still. I'm ultimately going for (ii). Someone wanted a reverse playback option, so bidirectionality is now part of the drive system's capabilities.
Steerpike's Toybox |
#244 |
DIY !
And you could add an external (push-)switch for energizing the mechanical brake-solenoid...
Arne K
Ars longa, vita brevis |
#245 | |
I am fully aware that we owe a huge debt of gratitude to Steerpike for devoting so much time and mental energy in designing a drive system for this motor. But I for one would be grateful if the design could be simply for a two speed option with absolutely no whistles and bells. Once the power to the motor is switched off the platter can be braked with the finger-tips. Solenoids, relays and other non-essential devices can only degrade the potential purity of the current. AND they are something extra to go wrong. I believe in the KISS principle and feel that for those who want to extract the utmost information from their records that this is the way to go. This TT treated sensibly with regard to plinth construction and with a very good arm/cartridge is capable of critical sound comparison with the very best TTs that can be bought at any price. However if this is different to the general consensus of requirement I shall be grateful if such addional features are designed in such a way that they can be totally by-passed/hard-wired out at building stage. Many thanks. Last edited by brianco; 3rd October 2009 at 12:45 PM. |
#246 | ||
Things like the mechanical brake belt: if you want it, there should be some electronics to operate it. If you dont want it, leave out the transistors etc. that energise it.
#247 | |
Thanks...just what I want to hear. Do you have any ideas on an approx. date by which you will be testing a first version? |
#248 |
Things keep happening that get in the way of fun; but I'm hoping to have "basic rotation" within a week.
#249 |
I, too, am interested in the design that keeps it simple (and adds the least amount of electronic / mechanical noise).
That being said, there are a few aspects of your design that I'm really looking forward to (over the stock controller). i.e. If there's anyway to rate them as high priorities, these are what I'd vote for: 1) The ability to sense the platter weight (MOI?) and alter the damping/speed adjusting appropriately. I'd like to play around with different after-market mats and would like to know that the added weight isn't going to alter the speed performance. 2) The ability to finely adjust the speed. As an example and as many have pointed out, 45s are not cut exactly the same all around the world. I'm less interested in the other design details. I plan to remove the mechanical brake and would like to investigate mounting the motor without the bath tub around it. As a result, I'd like to put as much of the electronics in an outboard chassis. Chris p.s. It's great news that a design is so quickly coming. If you don't me asking, what do you plan to come out with and what will be left to the design? |
#250 | |
After that is proved to work, I'll have numbers that I can plug into the PLL servo theory. *IF* the ASM PLL works, then the next step will be quite quick. I'm hoping to have a basic design that can run minimalistically without a microprocessor. But the micro will add a slicker user interface, and functionality such as numeric speed readout, fine pitch control, auto calibration, etc. *********** Long ago someone gave me this damaged 'generic' power supply (photos below). It's too complex to waste time reverse engineering it for repair. The transformer is still good, so it will make a neat box for the SP10 power supply, with a new PCB. It's 9" x 4". The umbilicus between the PSU and the SP10 I'm thinking of terminating with 25pin "D" connectors (as used, though not so much recently, on desktop PC ports These plugs and sockets are inexpensive, easy to source, have lots of pins, and quite good current rating.
| Technics SP10 | haydn | Analogue Source | 10 | 27th October 2011 03:18 PM |
| Technics SP10 MKII/SH-10E Voltage Conversion? | neiljadman | Analogue Source | 1 | 26th October 2009 09:45 AM |
| WTB: DC motor and controller | g-horn | Swap Meet | 1 | 14th March 2008 05:14 AM |
| Servo motor controller? | keantoken | Everything Else | 0 | 9th December 2006 08:49 AM |
| TEchnics SP10 MK II Turntable | diyman | Analogue Source | 15 | 17th December 2001 03:28 PM |
| Page generated in 0.15078 seconds (82.04% PHP - 17.96% MySQL) with 11 queries |
