Micro-Seiki MB-10 TT - Too Slow..! - Page 3 - diyAudio
Old 11th April 2008, 11:47 PM   #21
The next section (45 rpm drive) is slightly narrower. It steps down in dia by about 4 mm from the lower section (90 deg edge on the step). This section is a "parallel cylinder", no "high or low spots"
well you might have answered that there. See the homemade pulley shown in the pic below. See the way its fatter in the middle and thinnner top and bottom - the motor angle is meant to be adjusted so that the belt rides on the widest part. But you seem to have that sorted.
Last thing I can think of:
Could you measure (accurately with a vernier callipers) the diameters of the drive pulley and the platter (where the belt rides) and work out the ratio of one to the other. So if the motor runs at 250rpm at 50Hz, the ratio of the pulleys should give you 250/33.3=7.507
After that I'm all out of ideas on what to do here....
Fran
Old 12th April 2008, 12:32 AM   #22
stoolpigeon's Avatar
At the risk of repetition, you cannot leave out the belt in this calculation.
sp
Old 12th April 2008, 02:42 PM   #23
makinson1's Avatar
Don't quite understand this. Doesn't the calculation depend upon the inside diameter of the belt, which is the same regardless of the outside diameter of the belt?
Old 13th April 2008, 02:37 AM   #24
What you have to look at are the effective diameters of the pulley and hub driven by a flexible belt of thickness t.
These can be approximated as actual diameter plus 0.5 t on each side ie actual diameter plus t.
Now if pulley and hub are the same diameter there will be no effect but because the pulley is usually much smaller there is a relative increase in its diameter.
I measured a Thorens TD160 to have pulley approx 13.8 mm and hub approx 159 mm.
Motor speed is 375 rpm so no belt hub speed is
375 x 13.8/159 = 32.5 rpm
I don't have the belt but it is probably 0.5mm thick so with a belt effective hub speed is
375 x 14.3/159.5 = 33.6 rpm
Difference is around 3%
sp
Old 28th February 2016, 09:37 AM   #25
I bought a replacement belt on ebay for my BL-10X and the speed was innacurate!
So i bought another one from another shop and it did the trick!
Check your belt thickness and stifness and use only one that's exactly the sma than the genuine part!
Old 5th March 2016, 08:34 PM   #26
bulgin is offline bulgin  South Africa
Can you check the belt's deflection - somewhere between the motor pulley and the platter rim?
It should be +- 4 to 5mm before you start feeling some resistance. It's difficult to guess from hot as hell Cape Town but the Micro Seiki turntables are favourites here at chez bulgin.
bulgin
Micro Seiki Tonearm. MiiB Analogue Source 2 28th May 2007 04:14 PM
Micro-seiki DQX-500 gotster Analogue Source 0 11th January 2005 08:44 PM
Micro Seiki 1500 Cobra2 Analogue Source 18 15th November 2003 10:33 PM
Micro Seiki MC ktigerb Analogue Source 0 27th May 2003 10:16 AM
Copyright 1999-2017 diyAudio
